- Jul 21, 2021
- 8
- 180
- 529
- Sf Bay Area, CA
- 2022 Bronco 2dr BL SASQ, & 1975 Bronco Ranger
- Badlands
(May 2022)
This happened in my 2021 Black Diamond 2.7 (4dr, SASQ, tow, soft top)....
Early in the morning I had the heater/AC off.... 65 degrees outside heading from CA to Flagstaff AZ for Overland West. I was starting up the Altamont pass and saw the temp go from 190 to 225 in a matter of minutes. At the top I pulled over.... at idle all of the louvers front both intercooler and radiator were completely shut. With this, I took it straight to my dealer.... They said nothing was wrong that is just the "AERO" benefits of the louver system... Had you had the AC on it would not have heated up????
What???? so the louvers would have opened to let air condense the AC refrigerant .... However with the AC off they just stayed shut....
EVEN AT IDLE????? Who uses their AC when the temp is 65 degrees????
Come to find out later, the louvers are suppossed to open under 16 mph which they clearly were not doing. Dealership service guys are BS artists!!!
So having said that,.... one fellow Bronco owner at Flagstaff who lives in AZ, was having the same problem, Temp hovering around the 205-210 range with his AC off and 190-195 with his AC on....
______________
(MOVE AHEAD Oct. 2022) NEW BRONCO ARRIVES
(finally after 2 years picked up my originally ordered 2dr Badlands 2.7 SASQ)
.... I have been keeping the AC "ON" to keep the louvers at bay from my passed learned experience....
Yesterday I was coming home from Lake Tahoe with the AC on going on hwy 80 from Truckee to Donner summit..... Same drill.... I was babying the car not pushing it over 65mph.... Same thing!!!! the temp sored to 230 ... pulled over at the summit.... LOUVERS nearly shut (at idle) with the intercooler louvers wide open.... Again this makes ZERO sense????
Also,,, Went up to Genoa Peak the week before with my '75 bronco in 2 wheel drive (1st gear) no problem reaching the summit zero coolant issues...
However...When I reached the Top on Saturday with the new BADLANDS Bronco the temp was 235 in 4WD Low..... AGAIN I COULD SEE THE LOUVERS WERE STARVING THE RADIATOR AND INTERCOOLER FROM GETTING AIR!!!!!
Is there anyone who knows how this interactive louver system is supposed to work?????
IS THERE A WAY THROUGH FORD SCAN TO PROGRAM THEM TO STAY OPEN????
Any help here would be greatly appreciated
______________
