Add light to storage area when you have a soft top?
DenNut
Troy
Denver, CO
I've seen a few options for adding an LED light to the rear storage area when you have a MIC top. Oracle has a pod that goes on the window, and another company had a bar that attached along the bottom edge of the same window. What I have not seen is an option for adding light for soft tops.
I notice that there is a spot in the middle of the rollbar that says "accessory ready." That's a great place to attach something, but what? Had anyone seen the equivalent of a dome light that could go there and be wired in with the other interior lights? It could also be wired to one of the aux switches, but I would rather it be on the same circuit as the other lights.
Ideas? [ thought about using a ditch light, but that will be way too bright. ]
BrentC
Brent
Calgary, AB
I installed a cheap LED strip and toggle switch along the front of the roll bar. I tied into the 12V wires inside the trim.
