@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
For those who are looking for a sleek, low-profile front bumper for their 2021 Bronco, the Stealth Fighter hits the mark. Designed for performance and clearance off-road, it also brings bold styling to the front end. At the center of the bumper are inset mounting points for up to a 30-inch radius light bar, or 8 cube lights. Towards the ends of the bumper are 2 additional inset mounting points, that can take a cube light each. This design retains the OEM parking sensors, and we include plugs if your model does not have sensors. Our adaptive cruise control relocation bracket is available as well.
The bottom panel features louvers to allow airflow to the intercooler. We designed a 3/16-inch aluminum skid plate to replace the factory plastic skid plate. This is an optional feature, as you can retain the factory skid plate with the Stealth Fighter bumper. There are 2 reinforced clevis mounts that take 3/4-inch D-Rings, that provide recovery options if you manage to get stuck in the mud, sand, or snow. As always, this Bronco front bumper is fully bolt-on and Made in America.
https://www.4x4truckleds.com/addict...022-ford-bronco-stealth-fighter-front-bumper/
  • Low Profile Radius Plate Steel Design
  • Universal Light Mount for Up to 30-Inch Radius Light Bar or 8 Cube Lights
  • One Cube Light Mount Behind Each Side Panel
  • Optional 3/16" Aluminum Skid Plate
  • Vented Lower Panel with Louvers for Intercooler Airflow
  • Retains OEM Parking Sensors, and Includes Plugs for Non-Sensor Models
  • Reinforced Clevis Mounts for 3/4" D-Rings
  • Adaptive Cruise Control Relocation Bracket Available Separately
  • Fully Bolt-On
  • Made in America
  • Hammer black powder coat finish
  • Satin black powder coat panel finish
  • Mounts for 30-Inch Radius Light Bar and 2 Cube Light
Secure your spot in line by ordering one from us here: https://www.4x4truckleds.com/addict...022-ford-bronco-stealth-fighter-front-bumper/
when you you releasing the rock sliders?
Prkelly
Pat
Washougal
Probably obvious Where does the Adaptive Cruise relocate to and have you tested it with it relocated?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
It goes behind the upper grill area. I've not personally tested it but I also have a Gen2 Raptor with a relocated ACC and it works perfectly fine.
MillerBuilt
Tony
Washington
Chevy 3500, Dodge 2500, F150, Mercedez E350
I’ll be putting the Rock Fighter winch bumper and curved light bar on my Wildtrak……and when it arrives in, God knows when, hopefully the product is cheaper by then🤞🏼
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Let me know when you are ready to order it. We'll put together a package deal for you with the bumper/winch/light
MillerBuilt
Tony
Washington
Sounds good…..we’ll have to fix up that rear bumper also!
TNcoupe
Decatur,TN
2022 Badlands, 1970 Bronco, 1955 T Bird
These narrow skinny bumpers look great.....the stupid crash bars sticking out look ridiculous with them.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Just cut it off... I mean before the Bronco that's what you did. You cut your crash bars off. At least with the Bronco they allow us to remove MOST of the crash bar. However if you really don't like them, you can just cut them off.
But these manufacturers are not going to tell you to do that since it's not required for installation and it's a safety thing. BUT when you start building trucks up outside of factory, you'll need to get creative if you want to correct things that bug you :)
TNcoupe
Decatur,TN
Do we know if they are boron steel or carbon steel??
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Bronc-itis
E
South Florida
Q50 (bronco soon)
Almost 3k with a skid plate.. Yikes
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
