Adding a tow package aftermarket
MConn
Shel
Pittsburgh
Nissan Murano
I don’t currently have a tow package on my build but I do have the MIC top and Lux package so I’m getting more realistic that I’ll probably receive a 22. I always thought towing might be nice to have but that I could add it down the line… I’ve realized if I’m shelling out this much money and waiting so long I might as well get what I want from the jump.
is there an aesthetic difference (or any difference) in getting a tow kit in my build vs down the line?
EvlNvrDys
Hunterdon County, NJ
Sure. 1 will say Ford and 1 won't.
There's also the 7 pin from the factory... If you need it.
So far we haven't seen anything special with the 1 from Ford. But maybe someone else has seen something I haven't.
Aftermarket probably be a good $300+ cheaper.
If my Base Squatch goes through, I'll add tow later. If my BB goes through, I have tow included. 🤷‍♂️
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
I’m getting a basesquach here so an aftermarket setup is going to be my best option
i‘m hoping to get a rear bumper with the hitch built in
Headsong
Asked answered 10+times. Harness and stalk.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
I’m getting a basesquat here so an aftermarket setup is going to be my best option
I'll look at those options too.
Sooner
Ted
Henryetta, Ok
Is there going to be a plug in option for a 7 pin plug on a base?
I don’t need brakes
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
I plan on adding something...worst case I will pay for the ford setup.
SuperFord
2013 Ford Fusion
the factory option Ford system comes pre wired and pre installed with all harnesses, & modules. You’ll have to hack into the factory wiring harnesses (by cutting/ splicing/ soldering or god forbid doing what most hacks will do and using”scotch locks”) to add it later if you want trailer lights. It would appear at this point that you can’t or at least can’t easily add the factory setup after the fact. Certainly not as easy as buying a pigtail or jumper harness.
if you just want a hitch for a bike rack or something then I’d say it’ll be cheaper to go aftermarket. If you think you might EVER want to use trailer wiring then I’d recommend just ordering the factory installed option.
Unless of course you don’t care about tapping into your factory wiring. My ocd is driving me crazy about cutting into the wiring on an expensive new vehicle when the option is there to have it all plug & play from day 1
PrepVet
North Central WI
A bunch.
I’ll get an aftermarket hitch and wiring. I won’t tow anything that will require the factory suspension changes.
Lakelife36
Ben
Interior of BC
Factory suspension changes?
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
Aftermarket Class IV is in my future...
i doubt there will be an available class IV hitch as the vehicle capacity is 3500#, a class III is maxing it out.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Wiring is easy to do for brake/signal lights. Does not require cutting, splicing, scotch locks, etc. There will be kits that are plug and play.
MConn
MConn
Shel
Pittsburgh
Nissan Murano
I’ll have to look into those! I’ve never owned such a customizable car before. I’m excited about the options but my poor bank account is not lol
