Adding/changing Items a la carte AFTER PURCHASE & drain plug differences?
RedHotLava
Red
DC
2005 Nissan Xterra
Hey All,
Will it be possible to add or swap items easily that aren't part of an original lower package, such as swapping in the new Signature LED lights later, or swapping to upgrade a Grill, front driving lights, etc?
Also, can someone explain the difference between the active drain plugs vs the passive drain plugs, what does that mean exactly? Is there just a purchase that needs to be made later to make them "active"? or will it require drilling premade circles, in the floor, etc?
Thanks!
Blackandbluebronco
Christopher
Wichita Falls, Texas
Ford Expedition
Hey All,
Thanks!
highly Doubt there would be an option to swap but I’m sure different grills and such will be included in their accessories catalog they’ve been touting.
as far as active vs passive drain holes. the active are going to just be a plug you pull out of the floor that goes straight to the outside. I’m just guessing, but when they say passive, I think that there is a spot in the floorboards where the higher trim hole would be standard would just be a knock out spot where the hole would be, just not through and through. Meaning you could knockout the holes yourself but not have all the rubber and areas that channel the water in the rubberized trims.
RedHotLava
RedHotLava
Red
DC
2005 Nissan Xterra
Thanks dude, to be more clear with my question, what I meant was, will it be easy to buy and swap afterwards, i.e. same screw mounts and just buy and swap the Base lights and get the Signature lights, differ color or upgraded grill and lights. I''m assuming yes, but I know sometimes if you have a lower model, say they won't have the extra electrical wiring ran, etc for certain items like a tow package if you didn't buy it.
Blackandbluebronco
Christopher
Ford Expedition
Oh, for sure they usually share all the same attachment points that the headlights on the base would use as they do on the badlands. I had a Toyota 4Runner that came with the crappy halogen. Wrecked the front and when the fixed it at the body shot I asked if they could order the newer led ones from Toyota and they said it was no problem and that they all use the same attachment points. ive Ordered replacement parts from ford for my expedition like headlights and tail lights and they have fit With no problems. I’m thinking that this is going to just be like legos for adults.
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
most parts will have aftermarket parts that will bolt right in. i'm sure there are going to be plenty of aftermarket styles for the grill. i was thinking of swapping the headlights as well. can't say for sure but it could require some programming or maybe a different connectors that aren't a part of the base headlight package. but i'm ready to do a lot of upgrades and go OEM+ styling on it. (for those who aren't familiar, OEM+ is basically upgrades from ford and other aftermarket companies that keep the truck looking fairly stock but give it a clean look.).
RedHotLava
RedHotLava
Red
DC
2005 Nissan Xterra
Roger that, thanks guys.
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
with a lot of the upgrades they can be enabled in there respective control modules by us dealers using fdrs or Forscan,they try to keep the parts fairly standard across a line.only exception I've seen is audio system upgrades that will need extra modules and harnesses.
RedHotLava
RedHotLava
Red
DC
2005 Nissan Xterra
For sure, how easily do you think it would be to upgrade the 8 inch screen to the 12 inch later? Do you think that part is modular itself or do you think it'd have to be a full dash swap?
Rednek
Jimmy
Northern Alberta
Cant say for sure until we get some more info in manuals at work,but most vehicles used a different trim panel that may include other modules to change(like the trim on my Fusion would include the heater control module also)
rmc523
South Florida
2009 Ford Flex; 2018 Mustang GT
Dash wise, it looks like there's just an insert to that fills in the space left when you get the 8" screen vs. the 12". However, it's hard to say what mounting clips are behind there, or more importantly, whether it has the computing power to handle the larger screen.
Corsair
Jacob
San Francisco
Escape
Pretty sure it’s been confirmed all trims get the passive drains.
Edit: From the Q&A
Q: Are the cabin drain plugs in all trims or just the “rubberized flooring/washout interior” and are the in both front/rear rows?
A: Active drain plugs are only available with the rubberized flooring. There are passive drain plugs in all 2- and 4-door Broncos.
Cobra Jet
NJ
2018 S550 / 94 Cobra SVT #13
In today’s Ford lingo usually “active” means the part is electronically automated via a switch... Are we sure that a Bronco’s “active” floor pan drains are not possibly going to be “activated” via a dash switch? :unsure:
Corsair
Jacob
San Francisco
Escape
Yeah, you’re right. Humans are smart but people are crazy and stupid.
I took it to mean complicated as in turning into something that’d fail, not as in people couldn’t figure it out. ??‍♂
