Adding Fog Lights to Badlands (Modular Bumper)
Virtual-Chris
North Vancouver
I would like to add some approved fog lights to the corners of the modular steel bumper on the Badlands. It would be ideal if the fog light harness and switch was there on the Badlands, but I'm guessing I will have to use the overhead aux. switches.
Has anyone seen a photo of the light switch on a Badlands to see if the fog light switch is there or deleted?
JHawk
Ray
Heartland, USA
Fusion Sport
I am not sure about the switch but it would be nice if it did support fog lights.
Rigid makes a nice setup for the Raptor. I emailed them and they will have a solution for the Bronco this summer. The Raptor setup has 3 lights per side
BigFootie
Wisconsin
No switch without fog lights.
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
That is the exact use that I will be getting out of the overhead aux. switches
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Baja Designs has some options that look decent. Will be interesting if they have direct fit Bronco options. The price is a bit better. I would like some amber spot/flood combos.
Erock
US
2018 F150 Alpine edition
I’d rather use the overhead switch. The button on my truck is sort of annoying to find... however, they do turn off on their own, so that part is easy.
5280Bronco
Denver
I thought i remember on the aux switch wiring video that they said they are only powered with the ignition/button in the on position. Maybe i heard it wrong though? So at least it wouldn't run the battery down if you shut the bronco off and walked away.
BigFootie
Wisconsin
No, this means they will shut off and therefore no battery run down.
BigFootie
Wisconsin
2fast4u
Rancho Cucamonga CA.
Shelby GT500 and Bronco Wildtrak
Ford Bronco Adding Fog Lights to Badlands (Modular Bumper) F143828918
I like this look. Looks built in like it came that way from the Factory.
5280Bronco
Denver
Exactly, i had said it wouldn't run the battery down since they would shut off.
Erock
US
That’s true @5280Bronco . I meant on my truck that turning the lights off unlatched the relay for the fog lights. Being on the overhead switch, they should turn back on when the switch is turned on, which I would prefer 95% of the time.
5280Bronco
Denver
Ah... sorry. Got it now. I agree.
