Disconnecting is never the issue. It's reconnecting and you would be surprised how much of a pita that can be sometimes.
I've done it all, manually removed the bolts and zip tied everything out of the way, JKS Quick disconnects, Currie Antirock, and finally settled on the following air actuated setup from Off Road Only.
Jeep TJ Sway Bar SwayLOC For 97-06 Wrangler TJ OffRoadOnly - OffRoadOnly
In Extreme rock crawling, with front and rear full width axles It's actually a big difference to be totally disconnected, vs having connected swaybars with longer links. When disconnected fully, the body will follow the rear axle. When you have both the front and rear sway bars connected, but with longer links to allow for articulation, the body will stay neutral even with the axles going in opposite directions.
