Additional dome lighting, Jim style
Just_Jim
Minnesota
2021 Big Bend
I'm still sorting out the relay issue to overcome the PWM dome power, but hope to have that resolved in the next couple days (waiting on parts to arrive).
I used these: LED lights
I tucked them up just below the rollbar airbag covers on the B&C pillars.
Ford Bronco Additional dome lighting, Jim style PXL_20220301_225217783
They fit beautifully in the little recess' on the cross bar cover for additional cargo area coverage.
Ford Bronco Additional dome lighting, Jim style PXL_20220301_225258560
The difference is remarkable!
Ford Bronco Additional dome lighting, Jim style PXL_20220301_225423858
Ford Bronco Additional dome lighting, Jim style PXL_20220301_225417014
I didn't take any progress shots, but I'll update with a couple tips when I get the relay issue sorted.
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
Looks great. Link to lights didn't work for me...
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
smahones
Shane
Denver, CO
Ford Expedition
How did you wire them in? Do they turn on with the other lights or do you have to use an aux switch?
SZairborne
Shayne
Minnesota
2018 Dodge charger GT AWD
If the side airbags go off, would these interfere with the operation of them or will the airbags launch these into the cabin?
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
These are attached to the pillar covers, not the airbag covers. The bags will deploy as they were designed and these will be out of their way.
I have them wired via a coil (traditional cube) relay off the OEM rear dome light, but it won't latch (aka: doesn't currently function). I got some capacitors in today, but also have a solid state relay (wide trigger voltage range) coming tomorrow. It's possible the capacitor would be enough to smooth the PWM power ripple, but I think the solid state relay is the better way to go.
SZairborne
Shayne
Minnesota
Thanks for the reply. I like your lighting mod.
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
Thanks! I'm just killing some time posting up my projects while waiting on FedSux to deliver my latest ham radio. 😆
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
Awesome. Waiting to see how your power solution works. Please post up final wiring instructions or notes about how and what you used.
Very interested in this if only for the cargo area and a couple in the passenger area.
Tarheel_Wes
Wesley
FJ
Is all this so they work with dome light ?
Could I wire them to an aux without Relays or capacitors?
Just_Jim
Just_Jim
Minnesota
2021 Big Bend
Yes, you could wire them to an aux switch and be GtG. I want them to work with the stock dome lights.
Tarheel_Wes
Wesley
FJ
ok
id Be interested in getting the front ones to do that
if you get it going can you post some detailed install instructions, as if you were instructing a 10 year old? Ha
Tarheel_Wes
Wesley
FJ
Oh, also
how’d you mount them? 3m?
Tarheel_Wes
Wesley
FJ
