Additional sound deading and quieting highway road noise
ThisGuy611
E90 M3 6spd Sedan; EG Base Scheduled 3/27
inb4 anyone says "it's an off-road rig, it's not supposed to be quiet!" - I understand that, doesn't mean we can't try to mitigate it somewhat :)
I'm sure we've all seen the reviews about wind noise above 65. Hard top vs soft top are about the same, though hard top might be easier to try and remedy. I believe the 2 doors are a bit worse with the rear wheels right there.
I saw somebody used velcro to secure a thin strip of sound deadening foam between the two front modular top pieces to help reduce windnoise. Seems like a cheap, easy, and not too intrusive solution. Has anyone else done/read about/thought of similar things we can do after purchase to help with highway noise?
So far the most common suggestion is upgrading the speakers :LOL:
CatcusGrey
Ryan
Seattle
Ford Fusion hybrid
Are you rocking a soft top or a hard top? I've seen a recommendation for soft top. Install the bestop mesh Bimini, adding a cheap blanket in between that and the soft top.
I have the Bimini, just haven't tested in a tunnel or at high speeds yet. Would love to hear if there are other suggestions out there for the soft top! Can be quite loud.
mykoljay
North NJ
2021 Bronco 2DR
Following! 2 door (hardtop) on 35s. very loud on the highway. Would love to figure out a mod to help.
Shefoot
Kim
Seattle
Trailblazer
I did 2 hours of higher speed highway driving home on Saturday. Soft top. Not super bad? Maybe I'm more used to is because of my truck or my blazer previously, but I only really noticed it at one of the rear windows.
ThisGuy611
ThisGuy611
I'm still waiting on my 2 door, so it's going to be a hard top. That's a great suggestion for the soft top actually, haven't seen that before.
My current car is a V8 M3 with an aftermarket exhaust, so it certainly isn't quiet, but I'll take engine noise over wind noise any day! I'm just hoping someone has found a solution to drop db levels below ~70 at 65mph+. I'm seeing 74+ decibels on most videos once the driver hits those speeds.
ThisGuy611
ThisGuy611
I'm in South Florida so highway speeds over here are 75mph+ lol. From everything I've seen, holding a conversation at those speeds requires raising your voice a bit..
Shefoot
Kim
Seattle
Trailblazer
I'm southern gal from Florida, so I already speak quite loud, lol. We were only at 70/75 for part of the drive, then we hit the 60mph zone the rest of the way home :( Husband rode with me, we talked the entire ride home. I don't think I spoke louder than normal. We did turn the radio down while talking though.
Kjbeggs
Kelly
2019 Ford Ranger
I recently installed the JTops bimini on my soft-top.
I took some readings using the noise app on my apple Watch doing about 75 on the freeway.
I then took a couple of 1/2" thick 2' X 6' Yoga mats and laid them on top of the bimini.
The difference in the reading via my apple watch was almost non-existent.
(Love the Jtops, btw)
Gtrekker
Gary
Hey, there has been several posts on it for MIC top. Here's a link that should help...
https://www.bronco6g.com/forum/threads/hardtop-sound-deadening-mod-using-kilmat.42746/
