If you are new to off roading and don’t plan to do any serious trails, just beginner stuff, do you need the advanced 4x4?
what’s the main difference?
Many threads on the benefits, but to your specific question, I would say the Automatic 4wd is more for poor weather conditions during more typically driving on paved or dirt roads.If you are new to off roading and don’t plan to do any serious trails, just beginner stuff, do you need the advanced 4x4?
I only want it for the Michigan wintersIf you are new to off roading and don’t plan to do any serious trails, just beginner stuff, do you need the advanced 4x4?
I’m with Gizmo on this, Illinois winters can be a yawn or a complete nightmare.I only want it for the Michigan winters
The advanced transfer case has a 2H mode so you can make it not engage the front, it's not like it's always monitoring.I was on the 4A band wagon but it is another nanny tied into the computer. I wonder, if a person opts for the basic 2 speed t-case, would it be easier to later change to an Atlas t-case without having the computer freak out? Visions of a twin stick Bronco dance in my head....
I would hope this is on Advanced Adapters radar.
Not the same as a CVT trans if that's what you are thinking. It means that where 4H is fully locked into 4WD, 4A has a clutch so it can be partially engaged and engaged while moving up to 50MPH I think. So what it means is that it can feed in some or all of the front axle as needed and disengage and you'll never notice and won't have to come to a complete stop to switch.Ford’s website lists it as on demand yet says it continuously varies power when activated. Doesn’t that make it sound more similar to say Honda’s AWD system or am I misunderstanding what continuously variable means.
Because front digThe advanced transfer case has a 2H mode so you can make it not engage the front, it's not like it's always monitoring.
Advanced 4x4
Where would the twin sticks come through the floor, there's going to be a center console and console mounted shifter. Would be a massive undertaking to do this, plus with the very low crawl gear on top of the advanced TC why would you need twin stick?
AMEN BROTHER......I HAVE A '17 FORD EXPLORER SUV WORK VEHICLE WITH AWD (W/RUBBER FLOORING) AND IT'S GREAT....ALWAYS BEAT 4 X 4 TRUCKS OFF THE LINE IN TRAFFIC!I’m with Gizmo on this, Illinois winters can be a yawn or a complete nightmare.
