- First Name
- Mitch
- Joined
- Apr 7, 2021
- Threads
- 91
- Messages
- 291
- Reaction score
- 998
- Location
- St. Louis, MO
- Website
- www.pandamotorworks.com
- Vehicle(s)
- 2021 Ford Bronco, 2014 Fiesta ST
- Your Bronco Model
- Outer Banks
- Thread starter
- #1
If you are looking for a new exhaust for your Bronco, AFE dropped a few different options for you! AFE provides you with a great system at a great price! Check out all the Options Below!
Apollo GT Series Hi-Tuck 3in 409ss Cat-Back Exhaust System
This 3" exhaust uses mandrel bent 409 stainless steel tubing and a high-flow stainless steel muffler to produce a deep tone. The High tuck design protects the cat-back and gives you additional ground clearance all while utilizing factory mounting locations. This system is designed to fit both 2-door and 4-door models!
Apollo GT Series 3in 409 Stainless Steel Cat-Back
Much like the Apollo GT Hi-Tuck, this system uses mandrel bent 409 stainless steel tubing but has 2 high-flow stainless steel mufflers to produce a a more mild tone. This system features a single, angled 4" tip with in your choice of Black or Polished Silver. This system was designed to fit both 2-door and 4-door models!
Vulcan Series 3" - 2.5" 304ss Axle Back System
This axle-back exhaust system uses 3" mandrel bent 304 Stainless Steel tubing that mates perfectly to the factory mid-pipe. This is a dual tip system that provides an aggressive, street-style look for your Bronco with your choice of Black, Carbon Fiber, or Polished Silver tips! The result is a mild tone.
Vulcan Series 3" - 2.5" 304ss Cat Back System
This cat back exhaust system utilizes the axle back system outlined above, but adds the mid pipe section to make this a true cat back. The mid-pipe section adds a 2nd high flow muffler with mandrel bent 3" tubing. This system mates perfectly to the OEM downpipe and uses all factory mounting points.
if you are looking to upgrade your exhaust, you should consider an AFE system, or one of the many other exhaust systems we offer at pandamotorworks.com!
