- Andy
- May 23, 2023
- 33
- 603
- 1,859
- North Alabama
- 2023 2 DOOR BRONCO, 2014 F150 XLT, 2006 F150 FX4
- Black Diamond
Nice looking rig!!!!!!!!!!!!!!!
THX.Nice looking rig!!!!!!!!!!!!!!!
The tie rods are weak and can break, there is plenty of evidence of this. I'm trying to decide if the steering rack boogeyman is real or just an over-imagined ghost based on a few stories. The golden question everone wants to know is: If I upgrade the tie rods, how likely is it that my rack then breaks? I feel like if you are running 37's on a lift, and you upgrade the tie rods (with sleeves, or beefier tie rods), you should at a minimum add the bushings in the rack - sounds like you've done that (were they BB or Rough Country btw, that's a whole other debateKind of similar setup, I have a spring perch lift with 37's and have the tie rod boogeyman under my bed as well. I have JKS tie rod sleeves and delrin inserts in both sides of my steering rack. I overland mostly but do enjoy the rocks when I can. Still have not broken a rack or tie rod yet, Knock on wood. If I do, I am upgrading to the HOSS 3.0 immediately.
Just remember, that was put there by some intern that didn't realize the reality of the situation.Nice!!! I’ll simply show Ford/warranty where it says” lift me BABY”![]()
2 other questions -11/16/2021 BUILT Basesquatch Rapid red, 3 inch ready lift, Icon Tie rods, 17inch Black Rhino Rapids, see what I did thereToyo Open Country AT3. Rear support Hammer built for spare. During install LH Rear reservoir was found missing. Trails in 3 days...
https://www.gorhino.com/i-30506845-...-with-rocker-panel-mounting-brackets-kit.html.2 other questions -
- what rock slider steps do you have?
- Thoughts on the tailgate reinforcement plate? I have a 37" spare on there which is plenty heavy, but those plates don't decrease load on the hinges, just distribute load across the tailgate and to the hinges from the sheet metal where the spare mount is. I haven't heard any squeaking or have any concerns really. Is there any noticeable difference w/ the reinforcement plate?
Would you recommend the Hammer built spare reinforcement? Cost? Install difficulty?11/16/2021 BUILT Basesquatch Rapid red, 3 inch ready lift, Icon Tie rods, 17inch Black Rhino Rapids, see what I did thereToyo Open Country AT3. Rear support Hammer built for spare. During install LH Rear reservoir was found missing. Trails in 3 days...
I really like the fit finish, highly recommended. Install was actually a little longer than expected. I installed in my non heated garage with outside temps -20, by myself. It was therapeutic let’s say. Easier in warmer temps I’d imagine.Would you recommend the Hammer built spare reinforcement? Cost? Install difficulty?
Thanks for the info! Your rig looks awesome!I really like the fit finish, highly recommended. Install was actually a little longer than expected. I installed in my non heated garage with outside temps -20, by myself. It was therapeutic let’s say. Easier in warmer temps I’d imagine.![]()
They are actually a good mod.I too began modding my base model Bronco... I added paracord grab handles!
Copy will do. Already missing the driver rear.Keep an eye on that rust on the shock reservoirs. Several people have reported the reservoirs popping off, with both Ford and Bilstein claiming this is not a warrantied item.
I assure the rack boogeyman is real. We had 2 Broncos lose racks on same day this summer. One was lifted with aftermarket wheels and tires, the other was bone stock Sasquatch. the stock one didn’t even have upgraded tie rods. Neither one had done anything to beef up the rack.The tie rods are weak and can break, there is plenty of evidence of this. I'm trying to decide if the steering rack boogeyman is real or just an over-imagined ghost based on a few stories. The golden question everone wants to know is: If I upgrade the tie rods, how likely is it that my rack then breaks? I feel like if you are running 37's on a lift, and you upgrade the tie rods (with sleeves, or beefier tie rods), you should at a minimum add the bushings in the rack - sounds like you've done that (were they BB or Rough Country btw, that's a whole other debate
I'm on the fence of just leaving it all stock and carrying spare tie rods (it's not a hard swap/fix on the trail), or doing the Icons + bushings and MAYBE the 74weld cap as well??
Dang, that's not good. What exactly went out on the rack? Did it crack the actual casing, or pop the pressure valve cap? Or something else?I assure the rack boogeyman is real. We had 2 Broncos lose racks on same day this summer. One was lifted with aftermarket wheels and tires, the other was bone stock Sasquatch. the stock one didn’t even have upgraded tie rods. Neither one had done anything to beef up the rack.
