Being that Bronco shares the same platform as the Ford Ranger, do you thing that after market running board, side step, and/or rock rails designed for the Ranger will fit the Bronco?
Besides doing Custom Graphics and Striping, I work with a Running Board Company in Bethlehem PA. We are currently looking for someone in the area to let us take dimensions and possibly do a test fit for a set of running boards. We need to see a 4 door and a 2 door. If someone can help before we find one at a dealer, you will be compensated for your help.
These are now ready to order. Check out the Romik Running Boards. They have a bunch of different styles and if you order, use my coupon code Bronco20 for $20 off. 2 door and 4 door are in stock. I use them for Dealer Jobs I install on other vehicles as well. I helped them do a test fit on both 2 and 4 doors. Easy Install using existing mounting points. https://romik.com/amfinder?find=2021-ford--bronco--19061&sid=KaprwkXHK1
