Can you tell me how many inches between ground and step, then step to step-in.
I haven't measured it. I'll make a reminder to do it in the morning though.Can you tell me how many inches between ground and step, then step to step-in.
Thanks
Roughly 15" to the top of the side step. Then an additional 10" to the inner door sill.I haven't measured it. I'll make a reminder to do it in the morning though.
Can you buy and install the Ford ones on a Badlands?If you look at the dominator sets, they are claiming to also offer some sort of slider support. Don't know if they would support the entire vehicle dropping down on it though.
You could also use your Ford reward points and purchase the factory ones for about half price.
Didn't the BD come with rock sliders or is that just the BL?
Also make sure you compare what you're missing out on by going with the BD. The BL would be a much better choice.
https://www.ford.com/suvs/bronco/compare-models/#blackdiamond|badlands
Yes, its been done. The rock rails will need to be removed.Can you buy and install the Ford ones on a Badlands?
I believe the Ford Rock rails or side steps are interchangeable and use the same mounting points basically. So you can have one or the other just not both.Can you buy and install the Ford ones on a Badlands?
thank youYes, its been done. The rock rails will need to be removed.
My wife says thank you as she can now get in & out my Bronco. I say thank you as I won't have to hear it every time she tries to get in and out.Yes, its been done. The rock rails will need to be removed.
Is that also the case with the Big Bend?Yes, its been done. The rock rails will need to be removed.
If I remember correctly on the Big Bend you can add tube steps while configuring the vehicle. I believe when you add the tube steps as Ford calls them it also adds the MID package.Is that also the case with the Big Bend?
That's correct, which I realized about 10 seconds after I posted and then checked the options chart. Though If I go with BB, I will probably want to pass on the Ford tube step and get a better quality aftermarket rail.If I remember correctly on the Big Bend you can add tube steps while configuring the vehicle. I believe when you add the tube steps as Ford calls them it also adds the MID package.
You are correct.That's correct, which I realized about 10 seconds after I posted and then checked the options chart. Though If I go with BB, I will probably want to pass on the Ford tube step and get a better quality aftermarket rail.
So I wonder if because that is an option, unlike some other trims like the BL, would it mean that there are no rock rails that have to be removed.
