Aftermarket lift for IFS and Sasquatch suspension
Delasangre
Oregon City
2016 VW GTI
Not sure if this was covered, but I haven't seen it discussed.
How far can you lift a IFS vehicle, its not like SAS where you just add huge leafs or long travel coils.
Also if you have the electronic Bilstein's will you have to ditch them to lift the truck beyond Sasquatch?
Is Sasquatch maxed out or will you be able to go more?
Advertisement
BroncBro
2019 Tacoma 4x4
With the right amount of money you can lift them quite a bit. To get an idea, look up suspension lifts for other IFS trucks and SUVs.
Delasangre
Oregon City
2016 VW GTI
Ahh yes, makes sense. But unless you use strut spacers you still run the issue of loosing the electronic shocks.
BroncBro
2019 Tacoma 4x4
I was unaware the coilovers were electronic. What does the electronics do for them?
Delasangre
Oregon City
2016 VW GTI
I think I am wrong about the electronic, I thought they were. I read "position sensitive shocks" and with all the stuff about goat modes I assumed they were electronic in some way but I guess not. My VW GTI has electronic shocks that stiffen or soften based on the drive mode, so I figured it was believable.
Electronic or not at a certain height of lift kit you'll need strut spacers or longer shocks.
395N
Orange County CA
BL 2DR incoming..
Electronic Factory Bilsteins?? Come again?
Coming from the 5th Gen 4Runner the safe zone is around 2.5-3 inches. I ran at 3.5 at one point and had CV binding and angry CV boot angles. I backed the coil overs (ICON) down to 2.75 inches and all was good. Some guys claim they run at 4 inches, but they may have been pavement queens. Not sure.
Delasangre
Oregon City
2016 VW GTI
Coming from the 5th Gen 4Runner the safe zone is around 2.5-3 inches. I ran at 3.5 at one point and had CV binding and angry CB boot angles. I backed the coil overs (ICON) down to 2.75 inches and all was good. Some guys claim they run at 4 inches, but they may have been pavement queens. Not sure.
Ya but will we be able to get 2.5-3 on top of badlands/high clearance suspension or over base. That would mean if 3 inches is max then the 1.5 of the high clearance/Squatch is halfway to the top.
395N
Orange County CA
BL 2DR incoming..
No one knows how far we can lift these Broncos to stay in the safe zone. Shit man, no one has even seen ths one move. IF Bronco IFS offers the same tolerane for lift as the dated 4Runner then I think 37's should be possible..without even going after market for UCA if in fact we can get away with only 2 inch lift. But no one really knows at this point.
Gamecock
2011 FJ Cruiser
Well, you’ve already seen Ford’s prototype lift that made plenty of room for 37s...probably 2” over Sasquatch lift, so a little more than 3.6” over stock. The aftermarket will be more aggressive than that. Yeah, when you get taller it takes more thought and you replace more parts, but it can be done, and will on Bronco.
395N
Orange County CA
BL 2DR incoming..
Amigo on 33” tires (stock is 29”) and a 5” lift. IFS is not an obstacle for lifting.
I have no experiance with Amigo's.
What I can tell you is that with my past rig there is no way to get 5 inches of lift for with any type of longevity and off roading. Unless you start looking at drop bracket lifts and or body lifts..both of which I'd not welcome on the Bronco.
What are you workig with under there?
Hulkbuster19
Mike Moore
Ca.
chevy tahoe
Vehicle Showcase
currie enterprises built an ifs for rock crawling........it can be done.....it just comes down to how deep are your pockets................I just wonder how long it will take for the first live axel swap kit to come out ?...............
395N
Orange County CA
BL 2DR incoming..
Solid axle swap would be rad. I can't wait to see it.
Sure rockcrawler IFS can be done and it works well...just look at KOH trucks. Awesome trucks.
Currie stuff is great and it can be done, but for most it's cost prohibitive.
Toccoa
Isuzu Rodeo Sport
Vehicle Showcase
There are always trade offs. From what I remember on this one, he did drop the front differential, but nothing else. As for longevity, it was already 15 years old when all this was done and he wheeled it pretty hard. Heck, he even converted it from an auto to a stick (in his driveway no less). Note: most Amigos get 1-3” lifts. This was just an extreme example to show it was possible with IFS.
MaverickMan
Shane
So i have an IFS Amc Eagle. Its only lifted 2.5 inches upfront with a coil spacer. No one makes suspension parts for AMCs pony style unibody cars that were converted into 4x4 by hair-brained mad scientists in Kenosha. So all the best mad scientists that have an Eagle on The Eagles Den have mostly done very custom fabricated home built lifts for their IFS (Eagles cant even cheat and do body lifts like the Bronco will be able to). They will create anything to get to 4" lift. So I would recomend to anyone wanting more than 3-4" lifts that may begin to require custom arms any higher, to start thinking about what parts are out there that work. Like is there an aftermarket raptorm arm set that can be adapted to your knuckles or upgrage knuckles to 1/2 ton size. Much higher than 3 inches and you really should be dropping the the diff a lil. Then you get to make a custom drop cradle that fits your bigger arms better. Also upgrade the diff and axles at this point too. If you aquired the ingenuity and ability to sort it out nice you would then have a better grasp of what amazing things you could do with it offroad. Sourcing existing parts any doing most of your own fab work you could build a high performance 6-10" inch lift that would give you clearance for serious wheeling on 44"s or so.
There could be alot done with minor suspension tweaks like a stretched wheelbase and custom fenders. If you did a 1 or 2 inch stretch on the rear and bigger fenders plus a lift you could run 40" inch tires or so.
Another option is going with 37"s of a more aggresive nature like Super Swampers or Mickey Thompsons TTCs and such. Its amazing what the difference in Boggers and ATs. It like regular tires are Adam West Batman, ATs are Michael Keaton, and Boggers are Hank F'n Cavill Zod neck snapping Superman!
The final option is portal axles. There are a couple companies who either make builder ifs portal kits for tubular arms or a bolt on type like from Tibus Offroad Engineering. Portals change nothing but leverage on joints. It just puts your axle centerline a 4 or 5 inches lower. It really is the ultimate clearance maker other than taller tires. I would have to imagine that a Bronco with 40" aggresive mud tires would be nearly unstoppable with a good set of portals and maybe upgraded joints, axle shafts, maybe diffs depending on your driving style.
Aside from all that wildness you could also just wait or trade back in for the Warthog model and put a spacer on it if needed.
I could also see a 1.5" body lift and baja fenders. Then stick to the 37s and drive it like a rental.
Advertisement
BDS Suspension
Advertisement
