Aftermarket Rear Bumpers with Tire Mount ?
LockedBronco
Frank
PA
1972 Bronco
Two t handle locks, one on each side (one for tire, one for the table and jerry cans)
Yes I see them.
How are they locking and unlocking?
Dmorty217
Derek
Venice FL
Camery
Yes I see them.
There is a round plate on top that has 2 holes in it that locks it closed or open. It’s dark and the bronco is backed in the garage but I can post a picture of it tomorrow afternoon.
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
Rockhard 4x4 also has one, which is the one I went with. It is a HEAVY beast but that is the point. I have had it installed for about a month now. No issues. I went with the 2 jerry can mount option. Love the bumper.
https://www.rockhard4x4.com/product_p/rh-60301.htm
Ford Bronco Aftermarket Rear Bumpers with Tire Mount ? image
Did you see any droop from the weight of the bumper? My only worry would be that 220LBS back there. Looks great.
AZBronco73
AZ
2022 Badlands SAS, 2015 Dodge Durango
Yes, with the added fuel and water it is about 300lb more than stock weight on the back end. I lost about 2.0 inches in ride height compared to factory SAS. I ended up going with the Eibach coilovers which are adjustable 0.0 to 2.7 inch lift over factory SAS. With the rear Eibach's close to max lift (still have about 0.25 inch left in the shocks), I am now sitting at about 0.5 inches higher than stock SAS. Up front I have a BAMF bumper with winch. I have the front Eibach's set at about half way up on the lift range (0.0 to 2.2 inch advertised range) which brought me close to the factory rake (about 0.5 inches lower in front than rear). I also have the Rockslide Engineering power steps which add about another 100lbs to my Bronco.
Eibach has heavier rate springs they are working on for their Coilovers. They are estimating that they should be out in 3-6 months. I plan on swapping the spring to the HD ones when they are available which should allow me to get about 2.5 to 2.75 in of lift even with all my added weight which will hopefully let me go with 37 inch tires when my factory SAS tires wears out (already have 10k miles in the 6 mo I have owned my Bronco). I will likely also go with an after market UCA when I go with 37s also.
mdonathan56
Perfect. Thanks for the info. I like the Rock Hard bumper and spare carrier, but just had concerns about the added weight.
