Aftermarket Transmission Pan for 10R60
  • Thread starter Deleted member 18651
  • Start date
  • Watchers 6
Silver-Bolt
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
I’m having trouble finding one that says it will work for the 10R60. Does anyone know any companies that make an aftermarket pan that will work for the automatic transmission on the Bronco? Of the first things I’m doing when I take delivery will definitely be to replace the plastic oil and transmission pans with aluminum ones.
You will likely have your work cut out on the oil pan. On the Raptor to change the pan the front axle needs to be dropped/lowered. Guessing that the Bronco will have similar issues. On the Raptor it is not a straight swap. The pick up tube also needs to swap. Make sure your pick up to pan clearance is correct.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I’ll be swapping the turbos so the motor will be coming out anyways, should make it painless once it’s at that point.
Does the engine really need to come out to swap turbos? I was pleasantly surprised with the room around the engine. In fact, it seemed like there was probably room for a pushrod V8.
Hoofnmouth
mark
N ca
ford focus st
What is a 10r60? I've never heard of it. My f150 has a 10r80 and my superduty has a 10r140. Is it a weaker trans that's in the bronco?
Its bronco specific it has velcro mounts to facillitate easy frequent removal.
2.3BigBend
PA
Work Beater
Looking at Ford TSB 20-2403 which applies to both the 10R80 and 10R60 for harsh shifts, that has you replace the valve body, it states two different valve body part numbers specific to either the 10r80 or 10r60, but only one pan gasket number. So it would seem, based off that TSB, the pan bolt pattern at least, is the same. I know the 10r80 pans I found when I thought about swapping my Ranger pan for one with a drain plug, were a few hundred dollars. No thanks...
mcinfantry
Lee
Louisiana
Badlands 2 door
NORCALGXP
Sacramento, California
2017 Raptor
Aonarch
North GA / MT
‘23 Bronco OBX 2DR Lux 2.7, ‘16 Corvette Z51
PPE transmission pan is great. Have one on the Ranger.
Fmuguira
Frank
Idaho
Jeep TJ
If a person wants a drain but doesn’t want to spend 250-300 bucks you can pull your pan when servicing and drill and install a drain plug …. I m giving that consideration over spending a wad of money.
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
I’m not sure drilling a hole in the stock plastic pan and installing a drain plug would work very well.
Fmuguira
Frank
Idaho
Jeep TJ
Good point… I ve done this on lots of metal pans over the years but had a brain fart and forgot our Broncos have a plastic pan … even if it’s thick enough to drill and put drain in still have weak ass plastic.
Short of hardcore wheeling a metal pan might take care of the drain plug issue and the risk of a stick or heavy brush busting pan without having to spring for a skid plate also. I know the pan sits up pretty high above the bottom of frame, existing transfer and engine skids.
swamp2
Are you sure on these?
This detailed guide from FMC does not indicate so: Link.
Mishimoto claims their +2 qt pan for the Bronco (non Raptor) is "easy" for the install. I would expect the Raptor to be similar/identical.
@kr_1315 did a factory fluid volume pan swap and maybe he can also comment (at least for the non-Raptor)
Ducati1098
He was referring to the plastic engine oil pan.
The transmission pan is an easy swap.
