Aftermarket wheels / tires for your Bronco?
Brokennose
Daniel
Scout
Is the Bronco that unique of an offset? I understand that noone has a vehicle that isn't yet released on their website. But find it hard to believe that whatever the offset may be is not out there.
ronstar
Ron
Illinois
F-150, Jeep JL
Isn't that about where the Squatch rims are? Hence, the wider flares etc?
could be. I saw another thread here where the badlands optional wheel has a 55mm offset. lots of posts where people say that the bronco wheel is the same as the ranger wheel. So I asssume most bronco wheels are the same at 55mm, but I can see where the Sasquatch wheel would have to be different.
Jr87mustang
Josh
Northern Cali
Aren't the Sasquatch negative off-set to make room for the wider tire?
Sas rims are +30 offset. About an inch difference from the +55 base rims.
Toccoa
Isuzu Rodeo Sport
Oakpv1
Patrick
San Francisco
2020 AWD Ford Ecosport
Requesting recommendations please...
I've ordered the base model 2 door Bronco in carbonized gray. At the moment, I plan to have the silver steel rims painted satin black and add aftermarket tires.
Can you recommend a tire brand and size that would look great and work well for a weekend camper that explores coastal California and the Sierra Nevada?
Also, I'm open to a new rim/size too. Thank you in advance- I look forward to your comments.
Hamhands
America
These rims may look good with rapid red. Who thinks 31x10.50 will fit on base?
FREEWAYPHIL
HAT
Plano Texas
FORD F 150 4 Wheel Drive
On the Black Diamond Can the stock 17" wheels take a 33" tire without lifts or body modifications?
If so we would trade out at our Dealer once delivered if possible. Got some time to figure
it out but any help appreciated. If not we would pick aftermarket wheels and tires and 2"
lift if needed.
5280Bronco
Denver
lift if needed.
Yes, it should as discussed in another post in the wheel/tires section of the forums. We'll only know for sure when someone does it.
I'm over here now trying to figure out if i can put a 9" wide wheel on the stock BD suspension.
mendozar74
Rodney
I know nothing about truck wheels and tires but coming from Subaru’s ive always been partial to Volks and Gramlights and Bridgestone tires. Not cheap. I don’t want cheap Pep Boys wheels or fake beadlocks and Since it appears there will be no Squatch with the manual transmission, will have to build my own.
Ford Bronco Aftermarket wheels / tires for your Bronco? Screenshot_20210124-085503
what wheels are these?
khoward9
keith
dearborn, mi
bronco
I had 18” and went for the 17x9 wheel with -30 offset and 315/70/17s.
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
I'm a base 2 door non-sas (carbonized gray). Going 17" wheels (Black Rhino Armory Gunblack) with 33" KO2's. I'm not wheeling just on the beach occasionally and backroad stuff up in Blowing Rock NC.
