Aftermarket Wheels | what options do you want?
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Hi Bonco6g!
The bolt pattern for the 6g Bronco has not been released, though pictures show 6 lug. Assuming the Bronco utilizes the same bolt pattern as the new Ranger, we can expect a 6-139.7 fitment range which offers plethora of choices!
Factory paint color options and of course the body lines of the new Bronco will be a consideration, however, we want to see what the enthusiasts think!
Do you have any suggestions for aftermarket wheels? Is there anything unique you'd like to see offered that's not already out on the market? Particular finishes?
You never know, the wheel manufacturers may listen and build something unique for the Bronco so share your feedback!
Advertisement
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis, 2017 Honda Civic, 2019.5 Chevy Silverado
Hi Bonco6g!
plenty of 16/17/18” Diameter by 8.5 options
no stupid mall crawler 24x8.5
dmtndan
1991 Silverado, 2014 Malibu
Hi Bonco6g!
Honestly like a wide array of types.... the older f150 sport rims I always thought were nice. I always told myself if I clever got a luxury GM product I would put these on them, and then the good ole’ regular pro comp Style.
edit: only issue with the F150 sport and the Denali rims is they are HUGE... wish they had them in a smaller diameter as I like more rubber than rim.
BroncoMatt
Matt
Plano
1976 Ford Bronco, 2014 Ford Explorer, 2015 Cadillac XTD
I would like to see a us mags 5 slot wheel that has the classic look. I will most likely put a set of Walker Evans Racing to match my 76 Bronco
JimmyDean
Louisiana
The smallest diameter wheel possible, up to 12” wide, set forward to keep width in check, old school weld style, like on that photoshop from maxlider on the main section.
And options for black and black/chrome trim ring and center.
FirstOnRaceDay
Devin
Toledo Ohio
smallest will probably be 16” due to brakes
FirstOnRaceDay
Devin
Toledo Ohio
I personally am hoping 16-inch works as well; I prefer the look of more sidewall.
ranger runs 16” on work trims. But I wonder if the bronco will have bigger brakes for the extra weight.
Jalisurr
Vancouver,BC
'97 Mitsubishi Pajero Evolution, '09 Corvette Z06, '08 ZX-6R
Vehicle Showcase
I'll be looking at Method to produce a 701 in the OEM size, I think we're expecting a 17" rim with a Raptor size 315/70r17 tire which will be plenty for me. Reasonably light, strong, and I like the looks.
JimmyDean
Louisiana
That in a 16 w/ some 37s would work for me if I go grey body and blacked out trim
Amos Moses
Trae
North Florida
71 highboy, 78 bronco, 79 bronco, 81 bronco, 84 bronco, 86 bronco, 91 bronco, 97 f250, 98 mazda b2500, 2011 f250
Something like this would be great, I'd put them on the 2dr with a different tire. :rockon:
Stampede.Offroad
SD
junk
Simple, light weight, structurally rugged.
One pet peeve is a pattern based on a number that does not match the lug pattern. So if it's a 6 like the Ranger and all the mules/prototypes then the 5/8/10 slot patterns make me cringe a bit. Find some 6, 9 or 12 slots that clean easily.
DrewBronc21
New York
I’m a fan of gramlights. Have 57Extreme on my Subbie. Here are a couple
Similar threads
