Alignment pin stuck in MIC HT
Techun
Pa
BD, 2.7, MIC, 4dr
I thought this would be trivial to pull out with a multitool. I'll try some high quality needle nose pliers, but has anyone pulled one of these out? Not sure if I should be trying to rotate or bend it out...pull straight, etc. It put up a solid fight for today so I'll tackle it tomorrow.
Ford Bronco Alignment pin stuck in MIC HT IMG_20211008_173211696
Ford Bronco Alignment pin stuck in MIC HT IMG_20211008_173207983
Ford Bronco Alignment pin stuck in MIC HT IMG_20211008_173159495
Jp215
James
Pennsylvania
2015 F150
Even if they can’t get it out, if you leave it alone they can take a picture of it and send it to Ford and get authorization to replace the glass section
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
I wouldn’t be touching it. Take it to the dealer
Techun
Pa
BD, 2.7, MIC, 4dr
I was able to get it out with minimal fuss today. I slid it around and eventually pushed it in so it went to the bottom of the glass. Then I found the area with the largest gap and pulled it out.
Ford Bronco Alignment pin stuck in MIC HT IMG_20211009_101453446
