Alternate Fog Pocket Solution Installed
Bigmoose
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
@Bigmoose did you end up using the 2nd, middle channel on the brackets?
No. As shown the SSC2 lights were against each other. I actually moved them apart slightly.
Djd7
Northeast
BD
Got it. On the backlighting.. since you opted to connect it, what did you wire it to?
Bigmoose
Bigmoose
Jon
RI
I have my backlights currently on an aux switch. Might move them to my parking lamps at some point.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Bigmoose
Bigmoose
Jon
RI
Brad Fx
U.S.A
Jeep Commander
On our KR Off-Road brackets you can fit any combination of 3x SS3 or SSC2. So whatever you like.
Then I suppose you could do 2 C2s and 1 C1 if all those will fit. 👍 Could be an interesting combo.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes you can run any combination of lights.
JAC
Joshua
Oregon
2018 Toyota Tundra; 2020 Acura RDX
@Bigmoose Thanks for this idea, and @4x4TruckLEDs.com thanks for the parts. I didn't have any issues with the install - will say it was a bit of a pain in the a$$ tightening everything up. That said, I'm really happy with the results; makes a world of difference.
Went with all white SSC2 pros, driving lights and fogs
Pics below:
driving lights on the inside and fogs out and recessed
Ford Bronco Alternate Fog Pocket Solution Installed IMG-0807
Headlights only:
Ford Bronco Alternate Fog Pocket Solution Installed IMG-0803
headlights and fogs:
Ford Bronco Alternate Fog Pocket Solution Installed IMG-0804
headlights and driving only:
Ford Bronco Alternate Fog Pocket Solution Installed IMG-0805
headlights, driving, and fogs:
Ford Bronco Alternate Fog Pocket Solution Installed IMG-0806
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah what I did was tightened all my lights when I mounted them to the bracket. There was just enough play that I could still aim them a bit.
