Alternate Fog Pocket Solution Installed
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
So I knew I wanted to put some fogs in the modular bumper pocket. I liked the idea of both a white light and a yellow light so I could use either based on conditions. I also felt that all the "triple" kits looked way too crowded in the pocket. I also thought all the 2x2 pods (Squadron or SS3) looked too big for the space. Just my personal taste.
I settled on two 1x2 pods. Specifically the SSC2 Pros because I wanted good light in the 1x2 size along with an amber backlights. I really like the look of the SSC2s in this space @Diode Dynamics. I used the KR bracket with harness from @4x4TruckLEDs.com to mount and wire everything.
Here are my post install pics. I'll try to update this post at a later time with some night time pics.
Bench Top assembly:
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211120_184440800
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211120_184444904
Installed in the pocket:
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211120_185251330
Backlights: yes they actually look different IRL due to one having a yellow lens.
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211120_193348895
Whites ON:
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211120_193406078
Yellow ON:
Ford Bronco Alternate Fog Pocket Solution Installed PXL_20211120_193425518
Bigmoose
Bigmoose
Jon
RI
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Yeah, you could say he "just bought the harness" lol. There was a lot of back/forth and changes. Finally he decided to get our 3x 4-Pin DT harness so he's prepared to add a 3rd light later on :)
Hard to find :( It's under the fog light section :)
Bigmoose
Bigmoose
Jon
RI
Ok maybe not hard to find. More like didn't know it was sold separate until I saw it listed under "other items" for a different product.
After seeing the space and being able to handle the lights, definitely won't be going with a third in the pocket. Could possibly utilize the third connector for a SSC1 on the corner, who knows.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
The setup looks great! How does it perform?
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Were the lights hard to hook up? I could use some guidance on integrating them in with the Bronco's system.
Cat
Cat
Whidbey Island, WA
PS...i bought the brackets. Harnesses, and 2 SS2s and 1 SS3 for each pocket.
Bigmoose
Bigmoose
Jon
RI
Not at all. The harness was a simple plug and play. I did go a little above and soldered my wires to my upfitters and used shrink tubing.
Bigmoose
Bigmoose
Jon
RI
Very well. I think the pros were the right choice. I'll try to get some good pics at some point. Hard to do in front of my house with street lights.
Draughon
Daylon
Dallas
BMW 4-Series
Looks solid and super clean! I'm a fan!
Draughon
Daylon
Dallas
BMW 4-Series
Not sure if these exist - but looks like 2 pods of 1x3's would fit that space perfectly.
Bschurr
NY
Nice job - looks good!
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
Bench Top assembly:
Ford Bronco Alternate Fog Pocket Solution Installed ditch lights
Whites ON:
Yellow ON:
Great effort, and so clean! congrats!
