That's awesome, thanks for doing that.I just snapped a quick pic of where my fuse tap is. To my understanding, this is #25. Middle row, 2nd from the left.
I'll try it later and report back.
Not a problem, best of luck!That's awesome, thanks for doing that.
I have that part already from SPV for my fog lights. It's very easy to install and doesn't require inner fender removal......just some loosening up of your airbox to get to the backside of the passenger headlight.I used one of these on the DD backlights, would be a much more elegant solution than a fuse tap:
https://specialtyperformanceparts.c...MI5ovv-erO_AIVKSdMCh2xWAkCEAYYAiABEgJDcfD_BwE
Downside is cost and having pull half the inner fender to get to the plug.
The clips are very tight when done correctly. Just make sure the light up letters are flush against your grille when you tighten them and you shouldn't have any issues.For those of you who installed these letters already, are the clips enough to attach them tightly? I heard from someone on Facebook that they are a little loose with just the clips, and they recommended to also add some 3M tape behind the letters. Thoughts? Thank you.
Good to know. Can you remove the letters from the clips once installed without destroying them? Only asking in case I don't get them on tight for some reason and have to back them out and/or start over. Thank you.The clips are very tight when done correctly. Just make sure the light up letters are flush against your grille when you tighten them and you shouldn't have any issues.
I used driver's side since all the wiring is there.I have that part already from SPV for my fog lights. It's very easy to install and doesn't require inner fender removal......just some loosening up of your airbox to get to the backside of the passenger headlight.
I'm either going to plug by light up letters into this device or run to an AUX switch. Haven't decided yet.
Unfortunately, I don't believe so. Honestly, calling them "clips" isn't completely accurate - they're more like rivets. You hammer them down using the tool included with the kit onto the backs of the letters. But the kit does come with extras in case you mess one up.Good to know. Can you remove the letters from the clips once installed without destroying them? Only asking in case I don't get them on tight for some reason and have to back them out and/or start over. Thank you.
Nope, those are clips. Push clips.Unfortunately, I don't believe so. Honestly, calling them "clips" isn't completely accurate - they're more like rivets. You hammer them down using the tool included with the kit onto the backs of the letters. But the kit does come with extras in case you mess one up.
Here's a picture of the extra K that comes with the kit with the mounting points highlighted.
I should really get some of these.They are great. I installed mine last August. They come in a great package, harness and installation tool. Love the look.
You’ll see this push washers used in many applications such as heating systems in vehicles. To remove them just take your pliers and squeeze them. Some might crack but they can be purchased at places such as napa.Unfortunately, I don't believe so.
Hey all,
So my Ecarzo Bronco letters came in today. The install was pretty easy, though getting the factory letters out took a bit of patience.
I prefer the look of these over the backlit Oracle lights, and wanted to share in case anyone else was interested.
Letters Lights Emblem for Ford Bronco Accessories 2021 2022 Front Hood Grille LED Logo Trim 3D Raised Decoration https://a.co/d/iBPDNNT
Great kit. You won’t be disappointed especially with the price. The letter K was added to avoid copyright laws. It’s a dummy with no leds in it. When you get the kit just toss the KI should really get some of these.
I'm trying to not buy any more accessories until it actually shows up. I lost track of the train but I think it should be getting here this week (who know how long from the port to the dealer).Great kit. You won’t be disappointed especially with the price. The letter K was added to avoid copyright laws. It’s a dummy with no leds in it. When you get the kit just toss the K
