Always on rear camera option?
beachman101
;pkl
So i noticed that the rear hatch and visibility is a bit small. Is there a possibility that we can have a rear camera always on option , maybe a transparency effect over the menu?
Its going to be hard for me to adjust going from a car made almost entirely out of glass to one that is basically a ww2 tank.
You think ford could enable a software update that allows something like that?
GoldenKnight
IL
Malibu
You see that in luxury full sized SUVs, where the rear camera will display full time in the rear view mirror if you want. I'd be surprised to see it in the Bronco though
MadMan4BamaNATL
Ray
Atlanta
If you search the internets, there are several rearview mirror replacement options where a camera mounted behind the vehicle gives you a video feed of the view. The new Defender has this option for when gear blocks your view.
These camera systems are usually less than $500.
Chrism81
chris
connecticut
Mazda
just get a rearview mirror that has the always on function. They have a camera that goes in the back. There are ones that just go over you current review mirror.
Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
I want the always-on option as a matter of principle. I hate nanny minders that turn certain features on and off because somebody on a committee thinks I am as incapable as they are.
Oneand0
Mario
South Lake Tahoe, Ca
Ford Explorer
This is something that I was thinking about, especially if people are seriously going to switch from a har top to a soft top in order to try to get a faster order. If a soft top is picked and later you're hoping to get a hardtop, you won't have the defroster and wipers. The idea of a rear camera you can flick off and on to get that view would be nice, if this was the case.
XirallicBolts
Xira
Wisconsin, USA
2016 Flex EcoBoost, 2022 Silverado LT
I know it's a feature on the Defender and usually uses a dedicated camera mounted on the roof, rather than the typical backup camera.
I've tried forcing rear-camera-in-motion on my Flex (Sync 3). It'd be nice for towing. Unfortunately I couldn't find a DIY solution that didn't have too many caveats -- tricking the radio into thinking you're in Reverse means the map runs backwards. Sync relies more on wheel speed sensors than actual GPS for navigation.
swooshdave
Portland, Oregon
Mustang
Wait a little while for people to get ahold of a Bronco and throw Forscan at it. Then we'll know. I wouldn't be surprised if there was a maintenance mode for the camera.
BroncoDymond88
New Jersey
'23 Bronco
Are you using magical side mirrors where you can see what is right behind you?
Anyone who has driven a Uhaul truck or has had cargo that inhibits the view of the rear view mirror would tell you that the side view mirrors are probably good enough.
Chrism81
chris
connecticut
Mazda
Good price but I'm sure it has the proper ingredients!
they have a 4k option w/ a 2k rear camera too. I was thinking of the higher end model because I want the best view and you can def notice a difference between 1080p and 2k
