I need to see these white 1552s on a Bronco… just making me get even more excited for the Heritage Edition!
Thats pretty in a retro, solid sort of way. Paint or powder coating? With all that spokeless, solid shape, that might work best as a body matched color! Like a set of Area51 colored, 17" x 8.5 wheels
a modern rendition of classic style.
Introducing the Analog HD, a modern rendition of classic style. As we continue in our journey to remap off-road performance for everyday use, we thought it'd be a good idea to bring back a classic steel wheel with some minor adjustments and added functionality. So we went to the drawing board and started with an all-aluminum construction to reduce unsprung weight, added some dimension to the center section that would channel airflow through the slotted pockets to your brake system, and included a reinforced flange design.
technicals .
DIAMETER WIDTH BOLT PATTERN OFFSETCENTERBORE WEIGHT LOAD RATING (LB) 16 7.5 6x139.7 (6x5.5) 0 106.2 23.46 2500 17 8.5 6x139.7 (6x5.5) 0 106.2 27.50 2500
*** Please Note, we have not tested 16" on the Full Size Bronco yet, however we will have accurate fitment for 16" fairly soon ***
shop analog hd .
CLICK ANY WHEEL FOR MORE INFORMATION
HAVING TROUBLE? CLICK THESE LINKS: ASPHALT BLACK / CLASSIC WHITE / PEAK GREY
Get 10% Off Your First Set with: BRONCO6G
07/26 UPDATE:
We have a large Analog HD container landing Mid-August, as this is the most highly requested wheel for the full sized Bronco, please put in a pre-order to guarantee yourself a set. Thank you for your patience with us as we continue to deal with shipping and production delays.
RENDERING
Have Analog HD on your Bronco? Post it below!
Someone more knowledgeable than I would have to answer the wear-and-tear question. I believe 30mm offset is what the Sasquatch and Wildtrak wheels are. I love the old school look but, in my head, having wheels/tires sticking that far out from the body is the antithesis of that great, old school look.A difference of 55mm on the offset. Is there a rule of thumb to follow on what is acceptable? Dig them in white, but would an offset of 30 be better in terms of wear and tear?
And a hub centric version for the Bronco would be nice!!!Plus one on the positive offset. Love those wheels but I don’t dig the wheel poke!
If you add options that match factory offset, I’d strongly consider switching my Badlands build from the optional wheels, get the stock and upgrade to these
technicals .
shop analog hd .
07/26 UPDATE:
RENDERING
????How about 16x10 or 16x8? I have a set of 35x12.50 r15 tires I want to use.
Oops I meant I have 35x12.50r16 tires so I'll be in need of some wheels 16x10 or at least 16x8. I've got time I don't a vin yet. 2 door 7speed Big Ben race red.????
would these fit on the stock SAS tires?I have the traverse HD
I'm all about looks, too. But if I'm going to tear chit up, I'd settle for a compromise. If 55mm is not possible, 30mm would look better (IMHO) than 55mm but possibly not alter the geometry to a point where possibly, the wear and tear would become ridiculous. Again, I say possibly. I'm not an engineer and perhaps while some of you don't like the poke, at 0mm offset, there would be no diff in wear and tear.Someone more knowledgeable than I would have to answer the wear-and-tear question. I believe 30mm offset is what the Sasquatch and Wildtrak wheels are. I love the old school look but, in my head, having wheels/tires sticking that far out from the body is the antithesis of that great, old school look.
