(Another) DIY Sliding Tailgate
Techun
Pa
BD, 2.7, MIC, 4dr
This is blatantly copied off of a previous post here that was removed.
Issues and/or things others should change:
Top lid doesn't open far (pictured). I can access things for now, so I'll live with it. I wanted to avoid a large gap so I'm stuck with it like this. I wish I had put a big chamfer on the mating pieces to allow it to open further.
The tiedowns hardware isn't sexy. I need to find something better eventually.
The 3/4 plywood bench is fine, I can sit on it. I will eventually replace it with 4/4 hard maple.
Ford Bronco (Another) DIY Sliding Tailgate IMG_20220121_200009550
Ford Bronco (Another) DIY Sliding Tailgate IMG_20220121_200318983
Ford Bronco (Another) DIY Sliding Tailgate IMG_20220121_200338161
Ford Bronco (Another) DIY Sliding Tailgate IMG_20220121_200054433
2Jeeps&PatriotX1
Denver, CO
Whats the overall height of the platform? Looks like it sits pretty flush with rear seats?
Techun
Pa
BD, 2.7, MIC, 4dr
The bottom supports are two 2x4s glued and screwed together. Then 3/4 ply on that. Plus 4 layers of carpet, so a little over 4.25".
You can make the top platform lower and smaller and try and have it line up with the top of the plastic hump, or go larger and over the hump like me. This is pretty good, if you had something like a sleeping pad you may not notice the ledge. Or for hauling items, since the seat backs slope up anyway this lines up pretty well.
Techun
Pa
BD, 2.7, MIC, 4dr
Updated with 1" thick maple. No deflection now, I would recommend over plywood.
I used poly on it...dislike the look. Poly never comes out flawless for me, I should stick to spray lacquer.
Ford Bronco (Another) DIY Sliding Tailgate IMG_20220209_112106648
Felix808
SRV CA
Looks good. If I didn't have plans for the liftable lid enclosure I would go this route. Nice job.
Headsong
I'd add some non-skid or carpet in case you want to stand on it...
Freebird32
Harold
97 F150 4x4, 82 Toyota 4x4 orig owner, 08 Z06
Looks great, thanks for sharing. Do you have a source for the slides? Thanks
BroncoStile
Todd
Alaska
F250 Tremor
Looks great I was thinking about doing something just like this but with a storage drawer instead of the table.
Techun
Pa
BD, 2.7, MIC, 4dr
I upgraded the wood to 1" hard maple. No flex now, very sturdy.
I put poly on it for waterproofing...but I hate poly. Oh well.
Techun
Pa
BD, 2.7, MIC, 4dr
Buck₩ild
Buck
Canada
Wrangler Willys, Bronco BD, Cherokee
I want one for 2 door😭
