Any aftermarket flares slightly wider than the sasquatch flares?
GorillaGrapplr
Tim
Wheeling WV
2021 Ford Bronco Badlands 2.3 Area 51
Does anyone make flares slightly wider than the sasquatch flares? My state won't pass inspection if there is poke
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
The air designs flares are about 1.25" wider than the sasquatch flares.
VIRUS
D
Wisconsin
Truck, car, feet
I used Ford Pass points for these. Pretty pricey but the points made it not hurt too much.
With zero offset and 37's, I have side lug poke.
They are the air designs
Ford Bronco Any aftermarket flares slightly wider than the sasquatch flares? Screenshot_20220903-102901_Gmail
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Those look amazing! Front view?
JeffROK
South Korea
2022 Outer Banks
I have Air Designs for the same reason. No poke on 35s and 0 offset wheels.
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
From the Ford Accessory catalog. Fit well over my 17x9 Fuel Blitz with 315/70x17 BFG KO2s.
VIRUS
D
Wisconsin
Truck, car, feet
do those attach like the stock flares?
Two different ways to attach.
Can swap the levers from the stock flares for each slot or they provide 3-4 bolts and nuts for each flare and you do a combination of bolts and levers. The bolts go in the upper slot locations for added support.
atlawson
Tracy
Rose Hill, VA
Bronco 2022 Wildtrack Lux w/ Sasquatch
Ford Bronco Any aftermarket flares slightly wider than the sasquatch flares? Screenshot_20221020-082952_Gmail
After installing these flares do you still have much water sling up on the front doors?
VIRUS
D
Wisconsin
Truck, car, feet
Still get stuff on doors.
Only way to mitigate would be to add mud flaps.
I don't care for flaps so I deal with the spray.
Have never had any problems with rocks and chips with MT AT's
atlawson
Tracy
Rose Hill, VA
Ok thanks I don't have any issues with paint yet, but have had some marking on my sasquatch flares. This is what I have now and looking for a little more coverage. It's not the greatest photo of how much poke there is. But I feel like an inch or so would get me covered.
Ford Bronco Any aftermarket flares slightly wider than the sasquatch flares? 20230417_141309
VIRUS
D
Wisconsin
Truck, car, feet
With that much poke, you would see a benefit with the wider flares.
Before I switched, I had water and mud coming up and spraying all over.
They aren't going to stop the stuff from hitting your doors though.
Looks like you have a decent negative offset.
