Any disadvantage with Swaybar disconnect?
broncosor
2022 Bronco Badlands
Hi, I understand well the advantage of having the swaybar disconnect offered by the Badlands. I was wondering though if there are any technical disadvantage with having it? For exemple worst reliability, or worst handling at higher speed?
I will do some off-roading with my Bronco, but I am not sure I’ll need the swaybar disco so I am trying to decide between Badlands and Wildtrack. If the swaybar disco brings some cons to the equation, I might go wildtrack.
beachman101
;pkl
wildtrack i believe has the GOFAST mode that the other models do not have. Its a dune runner vs the badlands which is more of a rock/trail crawler
Felix808
SRV CA
If there ever is a problem with it I'm just going to chuck it. Drove for years without front & rear sway bars on my XJ.
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
They suck when disconnected at high speeds.
Although, they are supposed to re-connect above 20mph.
Chadillac
Chad
Between the Hedges, Georgia
‘21 Bronco
I hope it is robust. I doubt it’s anything I’ll use much if ever but I don’t want it to be problematic. My buddy’s JKU was a nonrubicon so he removed the Sway bar bolts and swapped them with pins and hitch clips. When needed, just hop out and pull the pin and bam, disco action. (I didn’t endorse this for street use)
pat86323
Patric
Flagstaff az
1994 bronco xlt
I was wondering this also, it seems to me to be an entirely new system of disconnecting the stabilizer bar, and i wonder about reliability of it, as well as the cost of repair in the event that it does go.
Squatch
Miami
toymaster
Leonardo
Wyoming
2023 Badlands
No disadvantage beside a more complicated piece of equipment than a steel bar. Some with JKs do not like the Jeep version due to failure. I've never had an issue with mine.
That said Ford is bragging about how robust the hydraulic design is. Time will tell.
Corsair
Jacob
San Francisco
Escape
Note: this is due to the electronics housing prone to water damage and not simply having disconnects. It's a complicated convenience, but I hope it's executed flawlessly.
And it’s possible that some sort of hydraulics failure could cause the same sort of malfunction in the Bronco. That being said, I’m excited about the feature in the Badlands.
zaki
'19 Lexus LS 500;'94 Acura NSX;'13 Landcruiser
Good point. In my simple mind any complication is a potential weak spot.
I do not need it but I am sure it in invaluable for serious rock crawling.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
In my mind it's just something else to go wrong. If the sway bar really limits articulation to being a problem, I'd rather have a manual disconnect. I just like more simple solutions that I have to worry about less. May never be an issue though.
toymaster
Leonardo
Wyoming
2023 Badlands
....I do not need it but I am sure it in invaluable for serious rock crawling.
I'll disconnect mine on flat bumpy ground as well, it reduces the bounciness in side to side movement in that scenario.
rtaylor
R
ID
19Raptor, 22Bronco
If it fails, probably around $1500 to replace. Also, since it is hydraulic you might gets leaks when the hoses or seals age.
