Check the specifications on the LEDs - many can handle 9V to 30V and if that’s the case you have zero worries since you would only be applying 24V.Okay, just wanted to give an update and also ask a question. I will include some pictures later, but I was able to wire everything up to two of the switches, but they do not quite behave the way I thought they would so I need some input.
I have the white wires going to one switch and the red wires going to another with the ground shared at the chassis. When I flip one switch, the fog lights come on by themselves. Check. I then flip that switch off and flip the other switch, and BOTH the fog lights and the spot lights come on. This matches what the behavior of the two positions on the kc switch would be doing. It's a bit annoying as I thought it would just be the spot beam by itself, but it's fine.
My concern is what would happen if I had just the fog switch on and then turned the other upfitter switch on? Would it blow something since there would be two 12v sources going to the fog light beam? This is where my electrical knowledge is lacking, so any help is appreciated.
I assume if I just make sure to operate the switches independently, I should be fine, but I'm just trying to safeguard against the scenario where both switches would get thrown. Anyone have any thoughts?
