Anyone cut holes in cargo mat to allow the tie down hooks to come through?
C_Copperpot225
Chester
Zachary, LA
2013 F-150 King Ranch
Has anyone cut holes on their cargo mat to allow the tie down hooks to come through? I ordered the floor mats, but want to use the hooks as well.
ATLbronco
Matthew
Charleston, SC
2022 Bronco Badlands
devhodge
Devin
Chi-Town
Honda Fit
I cut mine. Very easy and clean looking if you take your time.
sirvegetable
Mini Countryman
Has anyone cut them but not completely? Meaning you make sort of a "flap" out of it so you can "close" the hole when not using the tie downs.
sirvegetable
Mini Countryman
If you're referring to the OEM cargo mat, it is actually designed for holes to be cut to allow access to the tie down points. See note in the instructions linked below; there are dashed cut lines indicated on the back side of the cargo mat.
https://www.fordservicecontent.com/.../21_Bronco_3_door_5_door_Cargo_Mat_Kit_v1.pdf
Mikehoncho
Maryland
Big Bend Sasquatch
I cut them out of my husky liner. Designed to be cut.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
As mentioned above I’ve got the husky cargo liner and it’s designed to be cut out if desired.. has little spots that show where to cut and works perfectly
