Please explain where you are getting a payload of 800lbs.Yep. A 4dr Rubicon payload of 1,081 is significantly more (35% more) than a 4dr BL (non-sasquatch) of ~800lbs.
This is just a guess, but I expect the tires are ‘C’ Load rated. Would moving to ‘E’ load rated tires and stiffer springs/struts increase the load capacity?After reading through the payload thread, I'm probably going to start looking at other options. I mean, I guess I could just wait until the kids are out of the house but with 2 adults and 2 teenagers, we're already over 600lb and I was looking at a 4-door 2.7 SAS BL. I thought my wife's TRD Off Road Tacoma was bad at 950lb payload...but ~700lb just does not work for us.
I won't consider a Jeep. Guess that leaves me with either a lesser Bronco, a 4Runner (depending on payload...local dealer has a TRD Off Road Premium and it's $12k less than the Bronco I had priced out) or just keeping my truck and picking up a SxS and trailer. Even though I love my truck, 5 years and 110k miles in, I've got the itch...
What to do...what to do...
Factory skid plates are typically not anywhere near what the aftermarket stuff is. They tend to be stamped steel, one and done and not very heavy. Similarly, the steel bumpers are not going to be the beefy $2k aftermarket stuff made of 1/8" steel plate. They aren't made of air but they aren't going to be that heavy either.It's kind of weird seeing the payload comparisons that people are making. This is an SUV and, depending on trim, a heavily armored SUV. Did people really think that steel bumpers and all those skid plates were made of air?
Nope, not really much you can do to change the GVWR once it's set. Those things will reduce your available payload though because they will be heavier.This is just a guess, but I expect the tires are ‘C’ Load rated. Would moving to ‘E’ load rated tires and stiffer springs/struts increase the load capacity?
Based on the base curb weights it seems like all those things potentially add a significant amount of weight. So while maybe not as hefty as aftermarket, they're certainly a lot heavier than their plastic counterpartsFactory skid plates are typically not anywhere near what the aftermarket stuff is. They tend to be stamped steel, one and done and not very heavy. Similarly, the steel bumpers are not going to be the beefy $2k aftermarket stuff made of 1/8" steel plate. They aren't made of air but they aren't going to be that heavy either.
My apologies. I meant to type 1,160 for the 4dr rubicon rather than the 1,081 for 2dr.Please clarify @2Jeeps&PatriotX1
You say “Yep” but then to me it looks like you contradict the article.
What?My apologies. I meant to type 1,160 for the 4dr rubicon rather than the 1,081 for 2dr.
From the article:
Payload ratings do vary between two- and four-door Broncos, however. Two-door models feature a max payload capacity of 1,170 pounds, while four-door models can carry up to 1,370 pounds. The Wrangler’s max payload ratings vary depending on which trim level buyers opt for, but range from 1,081-1,220 pounds for two-door models, and 1,160-1,310 for four-door models.
https://www.google.com/amp/s/fordau...ifications-are-competitive-with-wrangler/amp/
Based on the tables I put together on the other thread, I est:Based on the base curb weights it seems like all those things potentially add a significant amount of weight. So while maybe not as hefty as aftermarket, they're certainly a lot heavier than their plastic counterparts
