Anyone running Heretic Fogs?
WildTrak
WI
'13 Raptor
Really like the look of how they fit in the mod bumper with no blockage....
Did a search and not a ton on Heretic here.
Any experience or opinions would be appreciated..
Ford Bronco Anyone running Heretic Fogs? 1645400769655
BitterBronco
Connecticut
2014 Tuxedo Black Ford Edge
Justin B McBride on YouTube does a review of them on his Major Tom rig - a good place to start. Itā€™s his video explaining his overlander setup
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I've not run them myself. I hear decent things about them. I'm PRETTY SURE we talked to them about becoming a dealer. In fact, I think we were SUPPOSED to add their stuff to our site but for the life of me I cannot find the dealer application. I may have just talked to them on the phone.
We sell fog kits that you can customize what lights you go with, with none of the lights getting blocked (we also manufacture our own mounting brackets right here in the USA)
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
waveform55
Brad
TUCSON
2012 F-150
My Heretic fog lights get in tomorrow, planning on installing Saturday.
Speaking of which, I'm a bit new to wiring things on vehicles but...
I've watched several YouTube videos and they seem pretty similar to Baja Designs and how they'll install? I have a Black Diamond so I'm already rocking Aux Switches and wiring.
I'm assuming it's as straight forward as running the up fitter harnesses from where they're mounted, up through the engine compartment and wired to whichever of the wires I want to run to whichever switch I want? The trend I've seen is fog lights going to switches 3-6 and since the Heretics should be similar to the Baja Designs running one set of the fogs to one switch and the other fog light part to another...should be easy peasy yeah?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Not sure what they include as far as a harness... but if they just do what Rigid does and give you a bunch of relay/toggle switch harnesses, you can buy our triple fog harnesses. I don't recall what connector they use but it's either a Weatherpack 2-pin or a Deutsch 2-pin, in which case you can buy one of our all-in-one harnesses:
https://www.4x4truckleds.com/installation-accessories/switches-harnesses/
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
I like how they did their bracket, it doesnā€™t use the three bolts in the opening like most. They will sell their bracket separately, but couldnā€™t tell me if the DD lights would fit. I wonā€™t consider non SAE fogs, so their lights are out for me.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
If you want Diode Dynamics, just go with one of these 2 kits
Open Style Bracket: https://www.4x4truckleds.com/diode-...-w-kr-off-road-brackets-for-2021-ford-bronco/
Flush Style Bracket: https://www.4x4truckleds.com/diode-...ad-bezel-flush-brackets-for-2021-ford-bronco/
BroncoAZ
Mitch
