los7883
los7883
TX
Chevy Corvette
*Spoiler alert, nothing we can do about the seatbelt
Ok so opened it up and this is what I found. All the noise is coming from under this plastic cover.
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat 53A51932-37E4-4A3E-B5EB-951386618268
On the cover you’ll see this captive steel ball that can move around on its own and I believe is what locks the belt when you brake hard. I saw another video of someone putting grease in there but worried it’ll restrict the ball movement too much.
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat 7B386926-E319-4DEE-8F65-CB581AB0317F
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat B3C5D76A-D851-4447-839D-552DB99F89AF
The plastic cover sits over this area, the second place that’s making noise is the little black piece in here that engages with the teeth on the spool for the belt.
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat 6FA9BA0A-11CD-42F8-B898-F1C3D8328E42
You can literally shake the seatbelt around and hear this little piece bounce all around. It’s really thin and light, don’t think we can do anything about that either.
So since we can’t modify any of that crap I decided to put killmat on as much of it as I could in an attempt to reduce the vibration or absorb the sound.
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat 82681FB6-36AE-46B6-98D0-65794ACEAB17
Doubled up on the side that has the plastic cover.
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat 3789E28E-E16A-4FE0-B6AA-3F5EB5347886
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat 3E8C3175-0120-4D71-BC66-CD5483970388
Gonna add more to the cavity behind the seatbelt and then put it back on. Hopefully it’ll at least quiet it down some. Kinda sucks that we can’t do anything else.
Bruno
Bruno
Montclair
I’m only hearing two rattles now. One sounds like it’s behind the sub enclosure so I think I’m going to take the enclosure off tomorrow and add Killmat behind that, but the second one is the stupid passenger side seatbelt. I know a lot of other people were having the same problem, did anyone figure out how to fix it or are we just SOL?
HOW ABOUT A $25 SEATBELT RETENTION CLIP....
https://www.stickerfab.com/products/seatbelt-retention-buckles-set-of-3-2021-bronco-4-door
seatbelt-retention-buckles-set-of-1-or-3-2021-bronco-2-4-door-stickerfab-4_677x@2x.progressive.jpg
Bruno
Bruno
Montclair
Ford Bronco Anyone solve the seatbelt rattle? Lined interior with Killmat sound deadening mat seatbelt-retention-buckles-set-of-1-or-3-2021-bronco-2-4-door-stickerfab-4_677x@2x.progressive
SLIGHTLY....OBSESSED....
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
lmfao this is exactly what I did to my Mustang.. Ford quality
Ksjrb03
Tx
F250
Great post. I had the exact same findings. Those seatbelt internals are causing the remaining rattling from my B&O sub. I also have not been able to stop it.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Everyone should go to dealer and claim an issue with seatbelt. Eventually they might have to replace/redesign or come up with some fix.
Area51BS
Ron
Those wouldn't stay attached to my interior panels.
Why so. There is some amazing double sided tape with adhesive promoter used beforehand. I have the door handle inserts and theme sob’s are stuck!
mikec426
Russellville, AR
22 4dr Sqtch, 20 Triumph Tiger Rally, '04 Yam FZ1
No idea. I even cleaned off the original tape and put on 3M VHB tape and they still came off. 🤷‍♂️
Rblizz12
Riley
Boston, Ma
Ford Bronco Wildtrak & Raptor
unfortunately my seatbelt retention buckles from stickerfab didn’t last long. They lasted maybe all of a week. The 3m product they use to stick on is awful. I wrote to stickerfab on social media and email, I got no response so I ended up taking the double sided 3M off and got a thicker one with some marine glue and put them on. So far they’ve worked.
Tippster
Tom
Seattle
Audi TT, Badlands
Seems like going deer hunting with a bazooka to me :)
Delli555
Massachusetts
GMC Acadia
So I knocked out the rear cargo area today, first time ever doing this but I think it came out pretty good. I’m only hearing two rattles now. One sounds like it’s behind the sub enclosure so I think I’m going to take the enclosure off tomorrow and add Killmat behind that, but the second one is the stupid passenger side seatbelt. I know a lot of other people were having the same problem, did anyone figure out how to fix it or are we just SOL?
Seems like a lot of work to deal with a seatbelt rattle. I think the easier solution would be just keep them buckled up at all times?
Kramku1
Council bluffs IA
Escape
My rear rattles so bad I just pluged it into the connector. So, a giant invisible nobody is buckled in, but at least it's not rattling against the sidewall.
I used Velcro strips and strapped it to the roll cage.
