- Joined
- Jul 16, 2020
- Threads
- 112
- Messages
- 954
- Reaction score
- 1,074
- Location
- Rancho Cucamonga CA.
- Vehicle(s)
- Shelby GT500 and Bronco Wildtrak
- Your Bronco Model
- Wildtrak
- Thread starter
- #1
How did you like the light? Also do you think it could be put in and replace the current third brake light over the spare tire?Did it my Jeep - mounted it inside my spare (37). Worked great. Likely will do it when I put 37s on my bd sas.
Do you have a picture?Did it my Jeep - mounted it inside my spare (37). Worked great. Likely will do it when I put 37s on my bd sas.
I’ll hunt one downDo you have a picture?
I found an almost identical kit from Baja Designs and installed it. It's probably the perfect location for off road use and to deter tail-gaters, but I now am required carry an additional socket for the outside hardware and an extra deep socket to remove the splines that come with the kit. Always have an impact in the back so that wasn't anything more. But it's a lot more steps when changing out a tire now.Fast Intentions (@Fast Intentions Inc. ) is making a universal bracket for chase lights that mount to the spare tire. The Rigid light that you mention might be a good candidate with it's combined functionality to mount on that bracket.
Since I had one of the Rigid Chase lights on my jeep - I called Rigid to see if they would sell me just the bracket and the lug nut extensions for the Bronco. I was told they do not sell anything separately, so you have to buy the whole kit. So that’s what I did, I’m waiting for it now as it was back ordered but I ordered the whole kit and will wind up selling my other chase like that was on the jeep.Does anyone sell those extended threaded lugs separately? $300 + is hard to swallow for those kits.
I hope you write review and post photos after you receive it. Will it also work as a reverse light or only as a third brake light?Since I had one of the Rigid Chase lights on my jeep - I called Rigid to see if they would sell me just the bracket and the lug nut extensions for the Bronco. I was told they do not sell anything separately, so you have to buy the whole kit. So that’s what I did, I’m waiting for it now as it was back ordered but I ordered the whole kit and will wind up selling my other chase like that was on the jeep.
frankly, it’s kind of crappy they won’t just sell you what you need since I’m already a customer of theirs and probably have over $4000 in rigid lights.
You can use it as a reverse light. It had a running light and brake light that were both red. But I think they sell other versions and you can get other colors. The one I had had a tail light, a brake light, a reverse light, and the license plate light in case you put your plate underneath it.I hope you write review and post photos after you receive it. Will it also work as a reverse light or only as a third brake light?
