Anyway to stiffen the rear on Eibach coilovers?
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
Ford Bronco Anyway to stiffen the rear on Eibach coilovers? IMG_4024
Ford Bronco Anyway to stiffen the rear on Eibach coilovers? IMG_4001
(These coils)
love her, love the looks, but the rears a little too soft and besides a Rock Joint, what else could I do, as when I break she dives, and once got a little squirrelly
Kenda Klevers btw, 35x10.5x17, lowered the psi from 42 to 38
Thanks in Advance!
Cobrafang
Thomas
GA
NASCAR uses spring rubber in between coils. No idea where to get it but something like that might work. :clap:
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Can't help with the springs, but 38psi is still way above your weight.
Fordified1
Bob
Mid South Texas
Wouldn’t you want to stiffen the front to reduce brake dive?
Eibach has an upgrade front spring for winch and heavy bumper applications.
Maybe there’s enough adjustment on the shock that you could run them IDK.
What say you @Caleb@PandaMotorworks ?
CarmeloS
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
Appreciate the replies, and see what the shops say as well
Its not terrible at all, still able to go from here to wherever without issue, just day and night difference between stock and all this
Muffin Top
TX
JK, MK, KK, TJ, DN
FWIW, my stock OBX has lots of brake dive, so I would imagine there could be very limited aftermarket firming compared to stock.
Seems like it could work. After dialing in the front, then do whatever needs to be done to restore rake via rear ride height.
Assuming Eibach's upgrade front spring will be properly balanced with their progressive rear spring for freeway ride quality.
ScLeCo
Springfield
Charger Hellcat
Stiffen rear springs to combat brake dive. Uh huh. You may also want to consider upgrading your rear brakes for increased breaking performance as well.
If you're lifted have you added a drop bracket for your panhard bar?
Given your description of the perceived issue I'd look there first.
CarmeloS
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
Ordering the rock joint soon and around town and on the highway, its compliant, just transformed compared to stock
