AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc.
Kluch
Jorge
Massachusetts
2021 Ford Bronco, 1958 Chevy Corvette
@EIGHTLUG Will the 20mm B.A.L.L.S. ever be available in orange like the Mono B.A.L.L.S.?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
Yes! We have hundreds being prepped right now for anodizing. They'll ship out early next week and should be back by the end of the following week. All of the same colors that are currently available.
Kluch
Jorge
Massachusetts
Very cool! When do orders open?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
FWIW: 1/4-20 x 1 1/2” Socket Head Cap Screws are the perfect length to avoid thread poke below the TAP.
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. image
redone17
Cold Spring, NY
Not the greatest pics. But, you get the point. Looking MUCH cleaner and more streamlined than my last setup.
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. AD60A2EE-932C-4BB9-BFBF-362805E1AEF0
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. ECF0F076-1616-4237-BA93-97831B2C2A96
Ford Bronco AR | BAM & TAP Billet Rail Accessories (BRAs): B.A.L.L.S./F.A.R.T/etc. EBD03E34-A316-4FAE-9B74-3B0D93216DC6
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Kluch
Jorge
Massachusetts
I’ll work on getting the website updated this week.
Don't mean to be a pain, just don't want to miss the first order window. Any update?
DC9atnight
Toyota Tacoma
I love your radio mounts. Do you mind sharing a link?
Roostracing
Joe
Raymondville, TX
1974 Ford Bronco, 1964 F100, 1997 F250 powerstroke
@EIGHTLUG Are there any updates on existing orders? I ordered the SLAP mount and BALLS on 01/30/2023 and nothing yet!!!!! I really needed these before April 12th. Never thought it would take this long.
ORDER# 6147
Is there a phone number to call to get a response?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
@EIGHTLUG are these going to be available anytime soon?
I want to say they are?? I know about 400 of them were shipped off to anodizing last week for anodizing. I would expect those back in the next couple weeks. We usually always have the cerakote finished colors in stock. Which one are you looking for specifically?
Kluch
Jorge
Massachusetts
Looking for 2 20mm anodized orange, like the mono balls are. You had said a few weeks ago the website would be updated but never saw it. Just hoped I didn't miss it.
redone17
Cold Spring, NY
Roostracing
Joe
Raymondville, TX
ORDER# 6147
Dunkin1959
Brad
Sebastian fla
2022 Bronco
Our AR | B.A.L.L.S. have officially dropped!
Use the code B6GB.A.L.L.S.20 at checkout for your bronco6G.com 20% discount.
Launch colors are: Graphite Black/Asphalt Black/Tech Bronze/Tumbled Matte Clear
1" and 20mm are available options.
*Disclaimer*
Any and all perceived innuendos having to do with male genitalia, acts of a sexual nature, or reproductive organs are solely grammatical coincidence. These statements are by no means to be misconstrued, as such. This is a very very serious thread about our line of top shelf 6061 Billet Rail Accessories.
The first ARCHETYPE RACING accessory for the BAM and TAP rails and mounts is the:
AR | B.A.L.L.S - Billet Aluminum Longitudinally Locking Sphere
What is it:
As the name suggests, this is a 6061 billet aluminum rail mounted ball. We started from scratch with our B.A.L.L.S. The modular design of our B.A.L.L.S. allows mounting directly to any 1/4-20 female threaded hole and to both our smooth rail and Picatinny rail designs.
Why are AR | B.A.L.L.S. better: Well, I mic'd three of the round ball mounts I had laying around from a certain three letter named company and they ranged from .96-.98". With this design, we went ahead and made our B.A.L.L.S. a true 1.00" in diameter. So, for starters, the B.A.L.L.S. are bigger.
Our B.A.L.L.S. aren't a dense plastic with an embedded threaded stud. We use 316 Stainless Steel hardware that's bolted through our 6061 machined billet ball mount. B.A.L.L.S. are machined to perfection, with exacting tolerances, through multiple lathe operations, to create absolutely the smoothest B.A.L.L.S. and provide substantial mating surface for your rubber socketed arm attachments. With the use of 316 stainless harware for mounting, the B.A.L.L.S. can definitely take a pounding.
Our mounting system employs two strategies to rigidly mount to ours or any other rail system. These mounting methods make the AR | B.A.L.L.S. very versatile. You have the base system that is the 1/4-20 bolt through the ball and into a threaded hole. What makes it even better is the base has a male Picatinny stud to keep your B.A.L.L.S. securely cradled as you tighten the screw. This is a very satisfying mechanical engagement.
Then there is the 'B.A.L.L.S. Washer' method. The shape of the ball washer cups the B.A.L.L.S. and converts what was the male Picatinny stud to a smooth base with an embedded Delrin composite washer (500° heat rating) to prevent marring or any 'stick' of your B.A.L.L.S to your BAM rail (TX, NM, NV, AZ, I'm looking at you). The female threaded billet receiver will fit in the slotted areas of your AR | BAM, from underneath, and create a fully modular 1/4-20 threaded location anywhere along the slotted rail section.
The B.A.L.L.S., assorted hardware, and adaptive pieces all come with the kit. Spare parts are stored in our AR | B.A.L.L.S - S.A.C.K. (Supporting Accessory Containment Kit). This is a laser engraved AR branded suede leather pouch for storing your unused B.A.L.L.S. accessories, until it's time to switch positions. Being a very soft S.A.C.K., this will keep rattles down when stored in your center console or glove compartment. Truly high class, in the world of B.A.L.L.S. stowage.
You can expect for our B.A.L.L.S. to be placed on upcoming accessories for the AR | MOSH. like the AR | THE D Grab Handle.
  • Pricing for B.A.L.L.S. kits is TBD. That should all be together by the end of the week (1/21/22)
  • There will also be a 20mm B.A.L.L.S. kit dropping very soon!
  • More renderings to be released this week so you can see our B.A.L.L.S. in action from many different angles.
  • Availability is out there a ways. BAMs, STIRRUPS, & S.I.T.H. are the priority. I'd expect the B.A.L.L.S. to ship out in March. Various colors are happening, right out of the gate!
Send info
