AR | BRONCO CLASSIC DNA Fender Badge
STX Bronco
South Texas
F150 SuperCrew 22 Badlands
I think the match is pretty spot on and as close as you’re going to get without going completely custom. I don’t have any closeups, but can take some during the day. Here are some additional photos for reference.
Thank you for the additional pics.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
Has anyone gotten a shipping notification lately? I was told last month that mine would ship out right after Thanksgiving. Still nothing.
n0xlf
Castle Rock, CO
2003 Mustang Cobra
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Anyone having issues with them coming off? Both sides of mine are now losing adhesion on the badge side in different places. If I push on them I got a nice pop sound when it unsticks. Very low mileage and always garaged...
Original installation: https://www.bronco6g.com/forum/threads/ar-bronco-classic-dna-fender-badge.47425/post-1867701
Did you use the adhesion promoter? I used it on one of the badges but not the other. Reason being it made a mess all over the paint and was super hard to clean off getting a rag in between all the intricate cursive letters of the script.
n0xlf
Castle Rock, CO
2003 Mustang Cobra
No, but the badge side was already stuck on (as I recall). The Bronco side is sticking nicely...
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
What do you mean the badge side was already stuck on? Regardless, not using the adhesion promoter may be the problem (even though the instructions say it's optional).
n0xlf
Castle Rock, CO
2003 Mustang Cobra
The pre-cut (likely VHB tape) pieces are sticky on both sides, thus having a badge side and a Bronco side. Adhesion promoter probably wouldn't help since the badge side was already stuck on there, unless it could penetrate the tape. It would be best to apply that at the time the badge side was stuck on.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Understood. The adhesion promoter instructions were to apply it to your body paint (Bronco side), so the VHB tape adheres to the clear coat better. Like I said, I used it on one of my badges and it made a mess that was hard to clean off. The other side I did not use the adhesion promoter because of this.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
Did yours happen to ship? If not, I can look into it.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Adhesion promoter isn't a glue, like you would think. The 'promotion' part of the adhesion is to help push the air bubbles out, between the surface and the 3M VHB, with a thick liquid that doesn't compromise the adhesion of the 3M VHB. So it's still a chemical with some adhesion properties, but it's not the be all end all of the badge sticking or not sticking. I know alot of you are dealing with temperature and humidity issues, so the 3M Adhesive Promoter can only help your install be successful. And yes, it can be a bit messy. I'd suggest, once the badge is pressed on and secured, to wash the area with mild soap to remove excess.
feeble
Shawn
Yankton, SD
2022 Badlands, 1977 Cobra II Monroe Handler
Could you check order 8242 placed August 24? Thx!
brauncoboy
Jared
Ford Explorer Sport Trac
Got back from a little work trip and had these waiting in the mailbox.
Ford Bronco AR | BRONCO CLASSIC DNA Fender Badge PXL_20231220_211103290~2
Do you have a picture of these installed? I’m thinking of doing the same colors. Thanks!
Oly_Bronco
WA
Still have not received mine, order #8194. Ordered on 8/22/2023. Hoping for an update soon.
