AR | GEAR JAMMER - Bronco 7 Speed Shift Knob
Status
Not open for further replies.
GameWarden
Todd
F-150
I like the way it looks, but it also feels much better in the hand than the factory knob. Perfect size!
TNBronc4344
JT
Kingsport
@EIGHTLUG Any update on the Chissel pics?
Herbie
Alex
Cleveland OH
2022 Badlands
BadSquatch
Wilmington, DE
72 Bronco
Enders - Looks great!
Did you have to pick the orange paint code? What was it? And, how close does it match?
EndersRide
Santa Barbara, California
2004 Toyota Tacoma
Thanks! I did have to select the color code, and it’s called Sunrise Pearl (PMB-4652). The color match is so close to the interior accents that I can’t tell the difference. (More importantly, the wife, who worries more about these kinds of details, agrees.) If I ever decide to coat the metal inserts on my Trailrax, this will be the color I use as a nod to the interior. (If you look at the production pictures first put out, you can see the difference between mine and the on site orange. Seems I was the only one to put in that color request.)
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
I’m still not getting it. Again, I’ve been machining, both manual and CNC for 50 years. I get it if you were trying to mass produce these using a manual lathe and a Bridgeport, but you can knock these out in no time with any modern CNC either lathe with live tooling or a 4 axis mill.
Every machining op, and there are three and sometimes four, depending on the spec of the order are all done on our ST-30Y (with live tooling), along with the threaded adapter, reverse lockout, other stainless steel machined hardware we produce in house for our accessories, and our myriad of titanium lug nuts. Also add in time for going off site to the local powder coat shop and getting in line there with all of our other parts we send them for finishing (MAGNUMS/STIRRUPS, Shackles, BAM Rail Components, D Handles/MOSH plates, various wheels, CALL SIGNs, SLAPs, Bronco Scripts/Placards... you get the idea, hopefully) then returning to us to receive the post machine OP in the same lathe (shift pattern). Then we fixture them yet again for a laser op. Then most everyone has opted to have the shift pattern color filled. We do this in house also, by hand. We also design all of these parts in house.
So, true, you may have been in a machine shop for however many years but we're much more than just a machine shop. We produce all of these bespoke and custom finished parts in house. The sooner everyone can get on board and realize that we aren't a factory and we all personally produce, custom finish, inspect, and pack every order ourselves, the better off everyone will be. If you want a mass produced, mediocre part, that looks just like the last part that was put in a box and put on a UPS truck, there are definitely companies for that.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Ogre - you may want to change your Chisel order to a White Bread. Chisels seem to be much further behind.
Chisel will be so worth it. Just wait. There's nothing like it. Not even Pagani has sauce like the CHISEL.
Ford Bronco AR | GEAR JAMMER - Bronco 7 Speed Shift Knob Screenshot 2024-05-14 180316
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Holy interpolated holes, Batman!
4:38 min of machining on that face alone. Gobs and gobs of surfacing. Another 1:42 on the backside. I still need to weigh it, but I’m guessing 25.5 lbs.
Ford Bronco AR | GEAR JAMMER - Bronco 7 Speed Shift Knob IMG_5796
HighVelocity
Big Sky Country
2019 Triumph Scrambler 1200, 2013 F350, 2014 F550, CCM 1052
Your aluminum recycler must love you!
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
That wheel is a gorgeous mix of classic and modern. Most tempting silver I've seen yet.
Hey assholes that want color fill. You're slowing down my Chisel order!!
coffeetwitch
kansas city
bronco
Maybe color fill isnt what is holding up your chisel. that wheel took up a lot of machine time.
Ogre
James
But it's pretty. And I didn't order color fill. So I'll blame the fence I'm not sitting on. 'Merica 😅
Status
