Sean492
Sean
Canada
70 Ford Mustang Boss 302 and 2011 Ford F150 FX4
AR | STIRRUP®
*SHIPPING Mid-January 2022*
The BRONCO community asked for it and we went to work! After reviewing what was shared from last year's SEMA Bronco, there was plenty of room for improvement, both in design and function.
Made from a sizeable chunk of 6061 billet, the STIRRUP is very beefy part and it will look right at home on an overland build, trail conquering rig, or your daily driver. It's five inches of width will give your boot or shoe a proper platform to assist you in climbing up in the saddle. The entire part is coated in RAL 9011 Graphite Black, then post machined to remove the coating from the top surface and reveal the raw billet aluminum and provide a very classy contrast. This will also give the STIRRUP years and years of rugged good looks. The more you step on the the more naturally worn the aluminum will look but it won't affect the Graphite Black coating.
The STIRRUP is mounted to your OEM rocker rail with M8 and M10 316 stainless fasteners. A single M8 bolt alone has 110,000 PSI tensile strength! The STIRRUP is definitely more solid than the rail it's mounted to. With its coating and the use of aluminum and stainless, the STIRRUP will require little maintenance and it will last the life of your Bronco.
The STIRRUP will be sold in pairs. This will also be a BRONCO6G exclusive part, at launch, and B6G members will always be eligible for the 20% discount. We're going to handle the purchasing a little differently this time....
AR | STIRRUP DROP BRACKET
Renders are below. The drop available from the standard STIRRUP is difference making 2". The drop bracket is substantially larger than the standard bracket. The STIRRUP Drop Bracket has been updated to the listing on the website as an option. For the majority of use cases the 2" drop would make a lot of sense.
The Drop Brackets retain all of the same ruggedness of the standard brackets. The exact same rail mount locations are used between the two brackets. So if for any reason you want to swap to a drop bracket down the road, it's a simple order and install deal. The Drop Brackets retain all of the same ruggedness of the standard brackets. They do hang down just that little bit more, so that's something to keep in mind if you do happen to find that trail with large rocks.
Drop Brackets are added to the website as both an option and will also be added later as a stand alone product. If you already have the STIRRUPS on order but want the Drop Brackets instead, email [email protected] with your Order Number. We'll make the note to your order on the back end so you receive the brackets you want, but you'll check out on the website for the new brackets, if it turns out that there's a substantial cost difference. There is no cost difference to change your order to the Drop Bracket.
Pricing:
Retail price for the AR | STIRRUP is $494.43
BRONCO6G members are eligible for a 20% discount, making the price per pair: $395.55
NOW TO THE FUN PART:
If you would like to pre-order your STIRRUP pair or set of four now, here's what you'll need to do.
1. Reply in this thread: SEND IT!
2. We will PM you with a one time use code for the ARCHETYPE RACING website.
3. Go to the link, also provided in the PM, to the STIRRUP, and you'll be able to check out with the BRONCO6G 20% discount.
4. Spam F5 on the tracking link, once you have it, while you're waiting for your STIRRUPS to arrive.
"send it"
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
The final sets of STIRRUPS will be wrapped up from powdercoat this weekend. We’re prepping for a rather large shipment of STIRRUP steps and clamp brackets to arrive later this week. This bunch of boxes is less than 1/3 of the preorders. 😬
Time to stock up on Red Bull. They say it gives you wings. If I drink enough of them, it might give me extra arms and legs, because I’ll be needing them.
FTNBubba
Ray
Atlanta
Ford F350
Send it
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Ford Bronco AR | STIRRUP®  OEM Rail Fitment, Billet Aluminum Side Step - Brongo6G Exclusive Part E7133908-888D-4D82-A039-9D5B8DB951A3
Coffee time! Hahahaha! Thanks Curtis!!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Just locked in my Base grill - which will tie in nice with my all black STIRRUPS! It’s all in the details! Thanks for your hard work. Can’t wait to see some final beauty shots.
BdubBronco
Kentucky
2021 Bronco BD SQUATCH
I’m pumped to possibly have the stirrups on by the weekend! Just purchased a set of blingy d-rings that might be a little on the impractical side. Hopefully they complement the stirrups. Any chance install instructions include a suggested location for each step on the rail?
Ford Bronco AR | STIRRUP®  OEM Rail Fitment, Billet Aluminum Side Step - Brongo6G Exclusive Part 349E9780-6BFD-4177-BA6C-5A5A67BAD302
Bronco21fan
Angelo
NewJersey
Great job on your guys end can’t wait to get these
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
There will be basic install instructions included. Where you place them is sorta up to you. There isn't much available adjustment forward or aft at each door location, due to the way the rail mounts to the vehicle. It kind of just fits where it can. Luckily, for both the front and rear locations on the 4 door, the step locations are 100% usable.
_finack
Fort Lauderdale, FL
2015 Lincoln MKZ
I see that this was all for preorder and "the final sets" are packaged for shipment. Was this a one time thing? Or will you be selling this item in the fire as more Broncos are built?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
The STIRRUPS will always be available, just like the Bronco6G discount. There will probably always be some lead time on the STIRRUPS. It's a lot of parts for us, but it's still small lot manufacturing (<1,000 units) and will fall into our partner's machine shop machining queue. That may change as we expand and standup our own machining operation, here at STARKILLER BASE. Lot's of things are happening here in '22!
