- Andy
- Nov 4, 2021
- 9
- 368
- 542
- Raleigh, NC
- No comment
- Wildtrak
Send it
Yes. The B.A.L.L.S. will be able to mount directly to those locations.
I have mine setup in this way and have found that the mounting holes are likely the perfect distance for the RAM setup I have from a previous vehicle. However, the rail mount holes are not the same 1/4-20 as everything else. Will the B.A.L.L.S. have an option to have a 20mm/1" ball mounted there?
Send it.AR | TAP BYODM - Trail Accessory Picatinny Bring Your Own Device Mount
Now LIVE on the website for preorder. The TAP will be shipping the week of December 27th!
Link: AR | TAP BYODM - Trail Accessory Picatinny Bring Your Own Device Mount
This is where the modularity designed into the AR | BAM comes into play. We bring you the
AR | TAP.
What is it? Well, it a simplified and more abbreviated version of the much larger BAM. It shares the same ruggedness and single mounting point on the dash as the BAM but in a much smaller footprint and visually more discreet package. It also shares the exact same center mount component of the full size rail. So if you already have the BAM inbound, you can simply remove the two longer rails and add the smaller picatinny rail. Just like that, you have yourself the TAP. In reverse, if you were to purchase the TAP, you will be able to purchase the two rails and turn your TAP into a BAM. Gotta love true modularity... Not to toot our own horn, but this is where all of the other rails will be left in the dust.
The picatinny rail also has a 1/4-20 threaded hole in the center, which carries from the OEM. This will work with your threaded RAM mounts or any other 1/4-20 threaded accessories. The center 1/4-20 threaded mount hole is flanked on both sides by slotted mounts locations for throughbolted accessories, offering more mounting flexibility.
For this initial run, only GRAPHITE BLACK will be available. We're doing this for two main reasons. Black is the most ordered color and to streamline production to get these in your hands ASAP! Tech Bronze and Tumbled Clear Matte will be available soon. We will also be producing small runs of custom colors.
The TAP is 6061 billet aluminum 5-axis and 3-axis machined, then anodized and post machined.
This will also be a BRONCO6G exclusive Bronco part and B6G members will always be eligible for the 20% discount.
Pricing:
Retail price for the AR | TAP is $135.00
BRONCO6G members are eligible for a 20% discount, making the forum member price: $108 with free shipping (plus and applicable sales tax).
NOW TO THE FUN PART:
If you would like to pre-order your AR | TAP, here's what you'll need to do!
1. Reply in this thread: SEND IT!
2. We will PM you with the exclusive BRONCO6G coupon code for the ARCHETYPE RACING website.
3. Go to the link, also provided in the PM, for the AR | TAP, and you'll be able to check out with the BRONCO6G 20% discount.
4. Spam F5 on the tracking link, once you have it, while you're waiting for your AR | TAP to arrive.
