- Josh
- Apr 25, 2022
- 374
- 531
- 178
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
ARB 5480100 Fits 2021-2022 Ford Bronco Under Vehicle Protection
ARB Under Vehicle Protection panels are designed to give protection to vital underbody components including steering, engine sump, transmission, and transfer case. Laser-cut, press formed and folded 3mm sheet steel is used in ARB UVP to provide superior strength.
The ARB UVP to suit the Ford Bronco consist of four carefully designed panels. The front, sump, and transmission, and transfer case panels bolt directly to the chassis to provide continuous under-vehicle protection from the front bumper to the rear of the transfer case. Each UVP panel includes a return edge to add strength to the 3mm panel. To retain the strength and protection required of an ARB UVP, full vehicle servicing will require the removal and refit of panels to obtain access to drain plugs and other service points. This provides an opportunity to check for damage and buildup of dirt and foreign matter. Provision is provided to drain engine oil only with a removable insert in the second panel. ARB's UVP will fit with or without an ARB front bumper.
