- Josh
- Apr 25, 2022
- 374
- 531
- 178
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
ARB Differential Cover, 12-bolt, Nodular Iron, Red Powdercoated, Dana M220, Each For 2021-2023 Ford Bronco 750012
Available here : https://ticklemybronco.com/products/ab-fb-arb-750012-t14-1
Price: $184.32
5% OFF USING AN5 code
When off-road, encountering obstacles and hazards that could inflict expensive damage to your differential is inevitable. ARB differential covers are made from high-tensile strength nodular iron (tougher and harder than carbon steel); they are engineered to protect the differential and ring and pinion from off-road hazards. Available for a select line of differentials, they are offered in red or black powdercoated finishes.
Features of ARB differential covers include:
* Computer-optimized, cross brace design increases the structural rigidity of the entire axle
* Helps keep the ring and pinion gears meshing on the flat faces of the teeth--greatly increasing ring and pinion life and overall strength
* Top-quality, rare earth magnets on both the drain plug and dipstick collect metallic particles
* Dipstick magnet allows the oil to be checked for tell-tale signs of internal damage
* Prolonged carrier bearing life (especially on high-output vehicles) from improved support of bearing alignment
* Approach/departure angles optimized by angled exterior surfaces that minimize hang-ups
* Unique dipstick/filler cap design allows differential oil level to be adjusted for rotated differential housings
* Low-profile drain plug resists damage from obstacles
* High-strength cap screws (included) are recessed into the cover for impact protection
Cover Bolts:12
Ring Gear Bolts:10
Cover Material:Nodular iron
Cover Color:Red powdercoated
Filler Plug Included:Yes
Drain Plug Included:Yes
Carrier Main Cap Support:No
Gaskets Included:No
Bolts/Studs Included:Yes
Quantity:Sold individually.
Fitment: 2021-2023 Ford Bronco
Price: $184.32
Cover Bolts:12
Ring Gear Bolts:10
Gaskets Included:No
