Are soft top broken tabs covered by warranty?
raynaldo
raynaldo
Tundra
I broke a small tab the other day removing my back window. Has anyone had the dealer fix it under their warranty? Why are they even tiny plastic pieces?
Ford Bronco Are soft top broken tabs covered by warranty? 346D0348-EBAB-40DF-9937-30F02272E460
Ford Bronco Are soft top broken tabs covered by warranty? 8FA50AB5-7FE3-402F-8E20-10758868CA4F
yokayyb
Marc
Vancouver
Bmw 340i, Kawasaki zx6r
nope not warrantied, already tried well at least at one of my dealership. they would need to replace the whole rear window panel which i got quoted for 700? i saw a quick fix on the forums though with a use of a paper clip which i was planning on doing.
ChrisB351
Shreveport, LA
2022 2dr Bronco, 2005 ZX6r, 1993 Mustang GT
Typically a broken part is not covered as it isnt a factory defect, but if you have a good relationship with your dealer/service dept, they might be able to help.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
I got mine replaced under warranty, sounds like yokayyb has a crappy dealer to me.
Yep. TSB 22-2055, covered under warranty. (y)
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Yes warranty work for kind as well.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
It is a TSB. and warrantied.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Got mine covered under warranty. If I ordered a new back window myself, quoted $240 by all the local dealerships. Dealer ordered a new rear window and reinforced with rivets according to Ford TSB.
JaxGtc
yokayyb
Marc
Vancouver
Damn dealership im going back then to get it fixed! But why wouldn’t tsb not pop up when i brought it in then? Such a hassle
Mango&Moose
SE USA
Scion xB / Toyota Sienna. RIP my 96 Ranger Splash
Soooo should I just pop all these off when I get my Bronco, do they replace all tabs if only one breaks?
Seems inevitable that the window will fail.
CheekyOldMan
Bar Harbor, Maine
2022 Bronco Badlands SAS
I ordered a new set of windows to have on standby… they will eventually fail or get slashed. It just is.
tynamo29
Tyler
Columbia, SC
Bronco base
Two of the plastic buckles that connect the back windows to the soft top broke on mine already, hopefully they will replace those for me too.
Headsong
Not supposed to remove it like that. Keep the corners on and just pop it out. Watch the videos.
bsquatch
New Jersey
21 Base Squatch, 22 Wildtrak
The bottom J hook on mine is actually broken. I didn't know this as I just got mine used a couple weeks ago. I wondered why the rear passenger side was kind of flappy sounding while driving and after inspection I found it. Does anyone know if this would be part of that TSB? It's astounding this heavy area of wear and tear is just made of small plastic connections.
