Are they a true 315/70r17?
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
Rakkasan187
NW Arkansas
2021 FE Bronco, 2020 Ram 2500
Well crap, there goes that theory.
I just thought it was interesting seeing them stacked up together like this. They are noticeably smaller than the Nitto 315/70s.
BC overlanding
IN/KY area
If no one said it already Goodyears run small I think they are 34.6. Actually most 35,s aren’t 35,s. most are 34.5-34.8. Like other said you will have to google actual size of each tire brand and model. To make sure your mounting a true 35 if you have to be have 35,s. As far as the tread wide differences no idea
Rakkasan187
NW Arkansas
You are correct not all tires measure out the same. In this case they both show to be almost the exact same per their specs.
Ford Bronco Are they a true 315/70r17? 1B82D7E1-10CC-4F57-8D9C-E4D8409C20D8
Ford Bronco Are they a true 315/70r17? 9CA785F4-935E-4A76-8470-7DCBDF758285
Virtual-Chris
North Vancouver
Wow.
The Goodyear is clearly not as wide as claimed. Or the Notto’s are far wider than claimed. Those concerned about sidewall compression due to the stack simply need to look at the top tire… there’s nothing there to compress on the Goodyear… it’s simply a pizza cutter tire.
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
Every tire manufacturer lists the outside diameter in the tire spec. Goodyear never said it’s a 35.” Ford says it’s a 35” but it’s not.
Rakkasan187
NW Arkansas
Most 35s are not a true 35 inches, but regardless it was interesting to see two different tires with the exact same specs for height and width and the visible difference between the two.
RatBronco
Morrison, CO
2014 Toyota FJ TTUE, 2009 Dodge Ram 1500
My cousin runs the 35"x12.5" 17" Goodyear Mud Terrains on his Jeep and they are noticeably taller when the vehicles are side by side, even though Goodyear specs them out as 34.8" tall. My unofficial 'field' measurement guess is that they are about 1" taller.
Drex
Jake
Wow.
The angle is far better in the bottom tire in the second picture to visually compare them, but the top tire(s) eyeballs about the same. My guess is that you didn't pay close attention to the original post and are looking at the middle and right stack (the right-most tire stack is a totally different sized tire that is a while lot bigger in every dimension) instead of the center and left stack.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Are those actually 315s or the 285s put on the non-squatch?
Rakkasan187
NW Arkansas
They are the 315s that come on the FE Broncos. All FE Broncos have the Sasquatch package.
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Nope, it's always by section width, tread width is typically 1-2 inches narrower
All I know is visually and probably physically the Nitto looks a lot Wider especially at the tread and that’s what I like!All Selling them first day when my Squatch comes………………………….🦗
RatBronco
Morrison, CO
I just measured and they are only 33.5" tall.
Ditto on selling them - anyone want to make an offer - only 3k on them;)? For the record though, they drive very good on the street, perfectly balanced and quiet. Off-road they aren't bad either, both on the rocks and in the snow. Probably make a good FJ or 4Runner tire.
rguest3
Raymond
Florida and Virginia
F-350, F-450, 2022 Bronco, (2) 77 Broncos
I measured my Sasquatch "35s" yesterday. Mounted on the Bronco they are 33.5" Tall. So much for 35s.
