MUDLVR
MUDLVR
Justin
Colorado Springs
2022 Badlands Sasquatch
BAUS67
redneck
Central PA
The CV axle is perfectly proportional
I may have missed it but, what spacer lift did you use???
........Just a top spacer????
MileHighCitizen
Al
Denver
Bronco 2D 2.7
@MUDLVR What does the "GENTILE" patch mean?
MUDLVR
MUDLVR
Justin
Colorado Springs
Trueblue2296
Adam
Tennessee
2021 Badlands, 2022 F250 Tremor 6.7L
Added a few things in my cold garage:
- 3" front / 2" rear spacer kit
- Camburg UCAs
- 4WP Adjustable Rear Trackbar
- BFG KM3 37" Tires
- KMC Wheels
Everything feels super smooth and the tires are quite. I feel ridiculously high up but it's a great feeling. The ride is slightly stiffer with the spacers compressing the springs more, but unnoticeable when I air down. I have to trim a little bit from the inner fender well by the pinch points but I'm used to doing that with all my Toyota's.
This looks great. I am looking to do something similar. What spacer kit did you use. I have a SAS Badlands also. Trying to weight the best options for going to a 37. One guy did the 1” front level kit and was able to fit 37’s with no issue. On the stock SAS Wheels. Also where did you get the AT-AT patch i need that.
MUDLVR
MUDLVR
Justin
Colorado Springs
MUDLVR
MUDLVR
Justin
Colorado Springs
Thanks! The spacer lift is from these guys https://fordrangerlifts.com/shop/ols/products/xn-big-bronco-bigfoot-lift-3-front-and-2-rear-2y40ama
And that AT-AT patch was a gift I got years ago. It's actually an FJ Cruiser body with AT-AT legs 🤣🤣. I had an FJ for about 8 years
MSparks909
Miles
ENC
2014 Ford F-250
Looks great! What are the advantages of upgrading the rear track bar? I have the same lift..getting ucas soon
Allows you to re-center your rear axle after lifting.
MUDLVR
MUDLVR
Justin
Colorado Springs
An adjustable rear trackbar is really needed for tall lifts. It maintains centered axle alignment by controlling the left-to-right offset of the rear axle. It helps a bit with axle hop as well. Not a bad idea to get an adjustable at some point but small lifts it’s not really needed.
MUDLVR
MUDLVR
Justin
Colorado Springs
jlaliberty
Boston, MA
MB
- 3" front / 2" rear spacer kit from Ford Ranger Lifts
- Camburg UCAs
- BFG KM3 37" Tires
- KMC Wheels with 0 offset
what is the bolt pattern for those KMC wheels?
BUDXR7
Ben
Massachusetts
2022 Bronco (hopefully)
- Camburg UCAs
- BFG KM3 37" Tires
Looks great. Look how badly these things need flaps in the front.
