Bdisco
Flashing my lights behind you, MA
ā€˜88 911,ā€˜15 Chevy 2500, ā€˜24 Acura Integra Type S
Well, they say a pic is worth a thousand words, and with all your asking, here you go. And, no zip ties or tape. 3/4 inch (inside of snake) fits like a glove and the roof panel holds it in place.
I expect a compliment for my clear pics!
Lifted with my finger so you can see how it lays...
Thanks Mountain,
Does this cause any issues with drainage? ie: blocking gutters
Fordā€™s fix for the water leaks along the windshield header was to silicone the crap out of it.
Beach_Bum
St. Augustine, FL
TXNavy
Christopher
Spring, TX
GMC Yukon XLT 1500 4x4, Jeep Liberty Limited
I only noticed a 27.5% reduction in ambient noise while driving. Not satisfied. Who do I see about refunding my $6.00?
Did you wax the insulation before installing? That automatically reduces quieting factor by .5 dB
mountainbronco
mountainbronco
Thanks Mountain,
I dont think so, look at the roof panel profile, this is underneath the side fold. If you find any moisture in that channel, you likely have a leaking roof at the rubber seals between panels. If anything, the snake will inhibit sideways precip from entering where that corse foam vent is!
Tarheel_Wes
Wesley
FJ
Do you also snake it around the front of the vehicle?
Like above the aux switches? Thatā€™s where I seem to get most of my wind noise.
  • Like
Reactions: Cat
BAUS67
redneck
Central PA
Jhuff
J
Toyota Tacoma and DR650
This a great cheap benefit. I have a Bestop, and need to look and see if the same size insulation would fit mine just as well.
For further general sound insulation, I bought $80 (two yards) of 5mm wetsuit material (neoprene pad with fabric bonded to each side for durability). It will be my sleeping pad when camping, but is stowed between my mesh top and roof. I can't say it was as big an improvement as filling actual gaps, but is a decent sound buffer.
Havoc1
07 F250, 20 Accord Sport, 21 HD
Ford Bronco Attention MIC Hard Top Owners - Wind Noise Reduction Hack 150d685dc99b1ba88b5c4c852e509a5f27906r1-350-194_00
When $6 and back woods engineering fixes almost $1mil worth of R&D...
R.A.N.M.J.
Rick
I suspect there was more D&D and less R&D for a lot of the development cycle.
Contact
Randy
Austin, Texas
Bronco Big Bend. FJ Cruiser
I wonder how often they will need to be replaced if one lives in high heat region because they will dry out and become brittle and flake off? I had some stored in my garage and wanted to use them to make some outdoor faucet covers during a freezing spell and they just crumbled in my hands.
