Audio intermittently, cutting out after new speakers
DarthAckbarious
FL
'23 Badlands 4 Dr
Thanks for any help in advance. I recently installed hertz 100.3 in the front corners. I installed the PRV in the center channel. I put 300 Hz bass blockers on all of these. I also put some poly fill in the speaker cavities. I installed the Mabett rear speaker pods and hertz DCX 165.3. I also put some poly fill in those speaker cavities since there’s a lot of empty space, but no bass blockers. I did not touch the sub or add an amp or anything like that. Does anyone have any idea as to what could be causing this? It seem to just start happening after I put poly fill in all the speaker cavities, and added in the rear pods and speakers. It was not doing it at all when I just had the speakers up front with no poly fill and with bass blockers.
EquusBronsis
Santa Barbara
2023 Porsche Macan GTS
First thing that comes to mind…recheck your connects including bass blockers to make they are solid. Poly fill should have no effect.
DarthAckbarious
DarthAckbarious
FL
'23 Badlands 4 Dr
Thanks I will do that
buschris
South Carolina
1968 Ford F100 Ranger
I also have this problem after installing all new speakers and bass blockers. Thinking of taking the capacitors off the 6.5"
