Audiophiles - which of these 2 speakers would you choose?
buzpro
Binky
Tacoma
Seeking all audiophiles ..... if you had to choose between 2 speakers with the descriptions below:
1. regardless of price or brand, which would you chose and why?
2. what are the ideal frequency ranges for the 4" dash speakers and the 6.5" kick panel speakers? (with the current wiring diagram)
Ford Bronco Audiophiles - which of these 2 speakers would you choose? Inked6 speaker wiring set up_LI
Choice of speakers:
A)
Ford Bronco Audiophiles - which of these 2 speakers would you choose? Amazon-com-Alpine-R-Series-6-5-Inch-300-Watt-Coaxial-2-Way-Car-Audio-Speakers-Pair-R-S65
OR
B)
Ford Bronco Audiophiles - which of these 2 speakers would you choose? DB652-DB-Series-6-5ā€-Coaxial-Speakers-with-Marine-Certification-Marine-Speakers-Polk-Audio
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
Iā€™d probably choose option B if sticking with factory head unit as the amplifier. higher sensitivity means louder with less power. Also itā€™s marine grade so getting caught in the rain with top off is less of a concern
mikey_photo
Allentown, PA
2021 2dr Badlands
I'd choose option B as well. Generally speaking, 90db (or more) sensitivity is where you want to be if you're just swapping out the factory speakers, without adding an amp.
I'm picking up my Bronco on Friday and am already planning on switching out the factory speakers pretty quickly. I'm going to swap the speakers and then I'll add an amp at a later time.
I'm likely going to go with Morel Maximo Coax speakers in all 6 factory locations. They really hit above the price point and make for excellent factory speaker replacements without an amp.
jmoney
Jesse
New Orleans
following...I too am waiting for someone to say which speakers worked best and were easy to install. I am also curious to see if anyone plans on opening that rear panel and throwing a sub into it - what type of set up they would choose.
buzpro
buzpro
Binky
Tacoma
so for the kick panels do you guys suggest going with a component woofer? a 2 way? or 3 way speaker?
EquusBronsis
Santa Barbara
2023 Porsche Macan GTS
There is more in play here than just speaker sensitive, although the statement are correct. Speaker impedance should also be taken into consider. For example if OEM is 2 ohms and is replaced with 4 ohms your amps will be cut in half. Therefore not play as loud.
Kick panels are best location. Component speakers would not violate speaker design consideration and also would be time coherent.
smrpilot
PNW
'15 Silverado 3500HD, '68 FJ40
I'm here to play along as well. I have the standard unit coming with my Badlands. I drove the dealers demo unit with the standard sound system and not impressed. Pretty sure with top off driving all you're going to hear is noise. So I'll want to do a speaker upgrade and keep the head unit, and keep it marine. Also may want to do a removable small sub or some sort of hidden setup. Space will be a premium in the 2 door.
Blksn955.o
Greg
Wentzville, MO
I ordered JL C1 400 4in for the front dash and the rear pods and C1 650 6.5in for the kick panel. I was really torn between the 6.5 2 way and the 6.5 component.
I ended up going with the 2 way (the 4in are 2 way as well). As the dash speakers seem to be already crossed over/limited in the frequency they get based on the wire diagram and the fact the forum member BroncoTPA posted a video and noted tapping into the 4in speaker wire they noticed little low end. Since the 4in dash speakers are almost a component in the frequency isolation I went with 2 way's as I was thinking if I went with the component I might just leave the satellite tweeter off and leave the 6.5 as a pure mid. I am still 50/50 but purchase has been made.
I also plan on getting a Kicker hs10 hideaway and mount it in the general location of where the sub would be (but next to the cubby hole).
Should be a decent rounded setup for around 650-700.
buzpro
buzpro
Binky
Tacoma
Ummm can you explain that in English? if I chose component woofers for the kick panels and get a high end pair of 4 inch 2 way speakers for the dash, would that act as getting the base on the bottom and the treble from the top? would that setup be a crisp, low distortion sound system?
Virtual-Chris
North Vancouver
Itā€™s been a long time since I was into car audio, but Iā€™m not sure you want two-way speakers with tweeters in the kick panels. That will draw your soundstage down. I would keep the mids/highs up on the dash and use the kick panels to provide the lower-end which canā€™t really be localized anyway. I would even put a low pass filter on the kick panel speakers.
buzpro
buzpro
Binky
Tacoma
Chris I'm talking about installing something like this in the kick panel .... not a 2 way, just a component woofer
Ford Bronco Audiophiles - which of these 2 speakers would you choose? 1627512301465
Ford Bronco Audiophiles - which of these 2 speakers would you choose? 1627512259013
Erock
US
2018 F150 Alpine edition
What are the ohms of speaker A?
Erock
US
First impressions... Iā€™d go with speaker A. I donā€™t generally like the tinny sound of the smaller tweeters. But, there are a lot of numbers missing.
EquusBronsis
Santa Barbara
Sorry, my mistake in reading. My brain read ā€œCoaxialā€ not component. Disregard non-English part. What youā€˜re proposing will work fine. Theoretically speaker drivers should be within a certain distance of each other. Whether you hear it or not in auto; doubt it.
