Auto stop/start only on the Automatic Transmission.
Cridlon
CLIF
Boise Idaho
2009 Honda Civic
I'm assuming that this is only on the ATs not on the MTs. Anyone know for sure?
Zeke013
Oregon
I believe it's on both - but only when you release the clutch out of gear on the manual.
My 2019 BMW M3 did the same.
zfischer
New Mexico
F250, Tacoma, 4WD Sprinter, BJ42 Landcruiser
I believe itā€™s all. Triggered to start by depressing the clutch on manuals.
Cridlon
Cridlon
CLIF
Boise Idaho
2009 Honda Civic
Well, I will definitely have to get used to that. I've never had a vehicle that does that.! Thanks
JBowles
Jordan
Ozark, MO
Ram 2500
Yeah clutch out in neutral is when it kicks in on the MT
JBowles
Jordan
Ozark, MO
Ram 2500
Stopping the Engine - Manual Transmission
  1. Stop your vehicle.
  1. Shift into neutral.
  1. Release the clutch pedal and the accelerator pedal.
Restarting the Engine - Manual Transmission
Press the clutch pedal.
A message appears in the information display if the system requires you to take action.
Message
Condition​
Action​
Auto StartStop Press a Pedal to Start Engine​
The system needs to restart the engine but requires your confirmation.​
Press the accelerator pedal, brake pedal or clutch pedal to restart the engine.​
Auto StartStop Select Neutral To Start Engine​
The system needs to restart the engine but cannot because the transmission is in gear.​
Shift into neutral to restart the engine.​
604Bronco
British Columbia
www.bronco6g.com
Not that big of a deal to turn it off each time you start the vehicle. If you can push a button to start the vehicle, Iā€™m sure you can press one more - itā€™ll become second nature.
Wanted33
Down south in Dixie
On the Ranger5g forum an industrious owner found that plugging a low draw led night light into the 110V receptacle will fool the system into into thinking it isn't ready to work. Works just fine, and a lot cheaper than the disabler you plug into the wiring. However, I have no idea if this will work on the Bronco.
Wide Open Roads
Stace
Massachusetts
'09 Outback, '57 Alfa Romeo Giulietta, '10 911 C2S
On some vehicles, it's pretty unobtrusive. On others, it really takes some getting used to. I suppose if you drive regularly in city traffic with stoplights, I assume you'll get used to it quickly. If you're in backwoods most of the time and occasionally have it triggered, it will likely catch you by surprise. At least it's avoidable if you find you don't like it.
MikeyFrog
Iowa
Hoping there is a small wire monitoring battery voltage we can unhook... no voltage, no turn off.
JTBros
Long Island, New York
GR Corolla
I used it on a manual Wrangler and it didnā€™t bother me in the slightest. Itā€™s just a part of building a car in 2021. Donā€™t know why so many people here whine about it.
crowdpleazer
Daniel
West Virginia
Ford Ranger, Honda Civic
Hmm, wonder if a dash cam would do the same...
