AUX switch
Whttiger
Sean
Seirra vista Arizona
I have a 2024 outer banks bronco and I would like to install the raptor AUX switches. Any suggestions
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
It can be done but you have to replace the entire fuse box, run new wiring harnesses, and take apart a good chunk of the dash/window trim to make it happen.
Not exactly easy.
You may want to get in touch with @sirius76. He just completed a similar upgrade but took some shortcuts in order to avoid having to do the entire thing. It’s not quite the factory setup, but it’s about as close as you can get without swapping out all of the parts.
And also his name is Bryan and it’s spelled the right way, which automatically means he is most trustworthy than all of those other Brians. ;)
His post is here: https://www.bronco6g.com/forum/threads/retrofit-aux-switches-install-completed.91406/
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
Says you,Brian
